Hi @Dave, @bko and @BDub,
I wonder if spark events also work on Spark-Server. I’m using the same firmware and I don’t seam to get any custom event. I do get open and error. Is there anything I should be doing?
Hi @juano2310,
I think this may be an existing issue – https://github.com/spark/spark-server/issues/22
I haven’t had time to dive back into the spark-server, but I’ll see if I can’t get some time during this next sprint.
David
Thanks a lot @Dave! This is an awesome feature
Hi @Dave, any clue were should l look in the code to try to fix this? I would love to dive in but I don’t know were to start.
Thanks a lot!
Heya @juano2310,
Thanks for the offer! I would think the issue would be in the CoreController subscribe system here
https://github.com/spark/spark-server/blob/master/js/lib/CoreController.js#L134
or maybe in the events catching code here:
Some disconnect between those two pieces would be the cause, I would think.
David
you will see the spark events appear with spark subscribe which shows all the events in the firehose
