I looked around the community... Maybe I'm missing another thread about it, but I'm having an issue installing the spark-dev pluggin in Atom.
(I also tried downloading trhe latest pre-configured version of the spark dev atom build, but I also get an error whenever I try to compile.)
Here is the error I keep getting when trying to install the package:
npm WARN installMany node-pre-gyp was bundled with serialport@1.7.4, but bundled package wasn't found in unpacked tree
npm WARN installMany nopt was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany npmlog was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany request was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany semver was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany tar was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany tar-pack was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany mkdirp was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany rc was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
npm WARN installMany rimraf was bundled with node-pre-gyp@0.5.26, but bundled package wasn't found in unpacked tree
gypnode-pre-gypnpm ERR! Windows_NT 6.2.9200
npm ERR! argv "C:\Users\Jason\AppData\Local\atom\app-1.0.16\resources\app\apm\bin\node.exe" "C:\Users\Jason\AppData\Local\atom\app-1.0.16\resources\app\apm\node_modules\npm\bin\npm-cli.js" "--globalconfig" "C:\Users\Jason\.atom\.apm\.apmrc" "--userconfig" "C:\Users\Jason\.atom\.apmrc" "install" "C:\Users\Jason\AppData\Local\Temp\d-115824-36412-17puie2\package.tgz" "--target=0.30.6" "--arch=ia32"
npm ERR! node v0.10.40
npm ERR! npm v2.13.3
npm ERR! code ELIFECYCLE
npm ERR! runas@2.0.0 install: node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the runas@2.0.0 install script 'node-gyp rebuild'.
npm ERR! This is most likely a problem with the runas package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls runas
npm ERR! There is likely additional logging output above.
@Moors7 Yeah, I was just looking at that. Still no dice. The problem comes about at actually installing the spark-dev, hitting install on it causes this error:
> runas@2.0.0 install C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\pathwatcher\node_modules\runas
> node-gyp rebuild
C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\pathwatcher\node_modules\runas>if not defined npm_config_node_gyp (node "C:\Users\Nick\AppData\Local\atom\app-1.0.16\resources\app\apm\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node rebuild )
> serialport@1.7.4 install C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport
> node-pre-gyp install --fallback-to-build --runtime=atom-shell
C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport>if not defined npm_config_node_gyp (node "C:\Users\Nick\AppData\Local\atom\app-1.0.16\resources\app\apm\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild --name=serialport --configuration=Release --module_name=serialport --version=1.7.4 --major=1 --minor=7 --patch=4 --runtime=atom-shell --node_abi=atom-shell-v0.30.6 --target=0.30.6 --platform=win32 --target_platform=win32 --arch=ia32 --target_arch=ia32 --module_main=./serialport --host=https://node-serialport.s3.amazonaws.com/ --module_path=C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport\build\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32 --module=C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport\build\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32\serialport.node --remote_path=./serialport/v1.7.4/Release/ --package_name=atom-shell-v0.30.6-win32-ia32.tar.gz --staged_tarball=build\stage\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32.tar.gz --hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.7.4/Release/ --hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.7.4/Release/atom-shell-v0.30.6-win32-ia32.tar.gz ) else (node rebuild --name=serialport --configuration=Release --module_name=serialport --version=1.7.4 --major=1 --minor=7 --patch=4 --runtime=atom-shell --node_abi=atom-shell-v0.30.6 --target=0.30.6 --platform=win32 --target_platform=win32 --arch=ia32 --target_arch=ia32 --module_main=./serialport --host=https://node-serialport.s3.amazonaws.com/ --module_path=C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport\build\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32 --module=C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport\build\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32\serialport.node --remote_path=./serialport/v1.7.4/Release/ --package_name=atom-shell-v0.30.6-win32-ia32.tar.gz --staged_tarball=build\stage\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32.tar.gz --hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.7.4/Release/ --hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.7.4/Release/atom-shell-v0.30.6-win32-ia32.tar.gz )
Failed to execute 'node-gyp.cmd rebuild --name=serialport --configuration=Release --module_name=serialport --version=1.7.4 --major=1 --minor=7 --patch=4 --runtime=atom-shell --node_abi=atom-shell-v0.30.6 --target=0.30.6 --platform=win32 --target_platform=win32 --arch=ia32 --target_arch=ia32 --module_main=./serialport --host=https://node-serialport.s3.amazonaws.com/ --module_path=C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport\build\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32 --module=C:\Users\Nick\AppData\Local\Temp\apm-install-dir-115824-11844-qfiapm\node_modules\spark-dev\node_modules\serialport\build\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32\serialport.node --remote_path=./serialport/v1.7.4/Release/ --package_name=atom-shell-v0.30.6-win32-ia32.tar.gz --staged_tarball=build\stage\serialport\v1.7.4\Release\atom-shell-v0.30.6-win32-ia32.tar.gz --hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.7.4/Release/ --hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.7.4/Release/atom-shell-v0.30.6-win32-ia32.tar.gz' (1)
gypnpm WARN installMany node-pre-gyp was bundled with serialport@1.7.4, but bundled package wasn't found in unpacked tree
npm ERR! argv "C:\\Users\\Nick\\AppData\\Local\\atom\\app-1.0.16\\resources\\app\\apm\\bin\\node.exe" "C:\\Users\\Nick\\AppData\\Local\\atom\\app-1.0.16\\resources\\app\\apm\\node_modules\\npm\\bin\\npm-cli.js" "--globalconfig" "C:\\Users\\Nick\\.atom\\.apm\\.apmrc" "--userconfig" "C:\\Users\\Nick\\.atom\\.apmrc" "install" "C:\\Users\\Nick\\AppData\\Local\\Temp\\d-115824-11844-1h1a10g\\package.tgz" "--target=0.30.6" "--arch=ia32"
npm ERR! serialport@1.7.4 install: `node-pre-gyp install --fallback-to-build --runtime=atom-shell`
npm ERR!
npm ERR! Failed at the serialport@1.7.4 install script 'node-pre-gyp install --fallback-to-build --runtime=atom-shell'.
npm ERR! This is most likely a problem with the serialport package,
npm ERR! node-pre-gyp install --fallback-to-build --runtime=atom-shell
npm ERR! npm owner ls serialport
I'll probably just switch to a VM for now, but it'd be great if it would work on Windows. Trying to get a common workflow for my team and it would be much easier for them on Windows.
@nichfons i have atom loaded on windows 10, and every time i upgrade it i have to recompile it to eradicate the bug, so if yours isn’t showing the red bug then you have a problem.
@suda seems to have crapped out, this morning atom said 2 packages to update, updated one but particle dev ver 29 refuses ti update, errors out similar to @nichfons above, virtually same errors, what gives was working fine till now.
So I just downloaded and installed the preconfigured spark-dev version of Atom, and it installed fine… I haven’t tried to actually compile a project yet, but it installed… The pluggin for un sparkified Atom still would not install.
