Spark Dev: Cannot find module 'getmac'
OK, try typing
set HOME
in a cmd shell. That should show you all the variables with home in their name.
I got the homepath and the homedrive
Hi @thespark
The point @suda was making is to go find this directory and delete it.
I don’t know if you have Windows installed correctly since mine returns home as well as the other things with ā€œhomeā€ in their name that yours does.
Look around–the .spark directory should be in an obvious place.
Thank you
So what do I do after removing the contents of the %HOME%.spark directory?
Try opening the serial monitor that you had problems with before. The .spark directory should be recreated with the proper contents the first time you it.
