Hi all,
where can I check out Spark Core sources? Are they present on GitHub or some other public repo?
Best regards,
Drasko
Hi all,
Best regards,
Drasko
Watch this space: https://github.com/sprk
Right now the core hardware repo is open source. When we deliver the Core, we will open source the firmware and more!
Yeah, this one I saw. I was looking for Cortex M3 FW and library API.
I also wanted to see how you implemented WiFi configurator - are you putting the CC3000 in AP mode, how doet it scan available networks and what interface does it offer.
I guess you have set-up proxy the server side, so server side SW would be interesting to inspect also - what is server technology, is it Node.js or maybe Tornado Web, what kind of database is used, etc…
BR,
Drasko
The CC3000 has a super smooth setup process called SmartConfig. This video is a little cheesy, but it demonstrates the use of the iPhone/Android app to wireless connect the Core to your Wi-Fi router:
http://focus.ti.com/general/docs/video/Portal.tsp?lang=en&entryid=1_w8m93z2c
Since the Spark Cloud will have to handle tens of thousands of connections, our server infrastructure will be a complex combination of many parts, but we will be releasing a simple, open source node.js app that people can use to run their own server if they prefer.
The REST API docs are a bit out of date and changing soon, but here they are to give you a flavor: http://docs.spark.io/
OK, so put to AP mode it provides a server, so that you can send new settings and put it to STA mode.
What I am concerned is:
BTW, I can not find previous message quoting on this forum - pitty, no answer embedding.
BR,
Drasko
If you highlight the text you want to quote, a little box will show up saying "Quote reply". If it doesn't you can also highlight text and then hit the reply button to do so. Different from a lot of forums but pretty smooth.
The CC3000 can not do AP mode—the SmartConfig setup process is totally different.
Will the cloud stack be open as well so that we can run our own local cloud servers? There are a couple of scenarios where I might not want devices communicating outside a local network.
Yes, as promised in the Kickstarter campaign, and as mentioned in my latest update on the status page, there will be an open source version of the cloud that you can run yourself.
