Have an odd issue that impacts one of my Xenon's but not others. I setup a button handler to output the duration of the button press and the String(duration) is causing an SOS14. According to the docs:
Semaphore lock timeout ( Since 0.8.0 60 seconds expired while trying to acquire a semaphore lock, likely due to dynamic memory allocation)
But the error is instant, not 60sec later. With TRACE level logging there is nothing shown between button push and crash.
This has been happening for a few months on different firmware versions but today I'm running it on 1.2.1-rc.3, here's my test code
SerialLogHandler logHandler(LOG_LEVEL_TRACE, { { "app", LOG_LEVEL_TRACE } });
Serial.begin();
Serial.println("app start");
System.on(button_status, button_handler); //detect mode button interaction
void button_handler(system_event_t event, int duration, void* )
//works
Serial.print("button pushed, duration =");
Serial.println(duration);
//Causes SOS 14: Semaphore lock timeout (Since 0.8.0 60 seconds expired while trying to acquire a semaphore lock, likely due to dynamic memory allocation)
Serial.println("Mode button had been pushed for " + String(duration));
The odd thing is with that last Serial uncommented, nothing comes through the serial, even with a decent delay. But comment it out and the 1st 2 Serial prints work. Likewise if you change that 2nd Serial to use String it'll crash there; ie
Serial.println(String(duration));
By the way, using String([some int]) works within loop so it's only in the handler that it causes this error.
I know there are better ways to do this but this seems like a bug.
