I am trying to include the GitHub library for the Sparkfun VL53L1X distance sensor [https://github.com/sparkfun/SparkFun_VL53L1X_Arduino_Library] into my weather station code.
I did this successfully in a small test program by clicking the “+” button in the web IDE and then copying the files
SparkFun_VL53L1X_Arduino_Library.cpp
SparkFun_VL53L1X_Arduino_Library.h
vl53l1_register_map.h
into the template tabs for my project. My code contains:
#include "vl53l1_register_map.h"
#include "SparkFun_VL53L1X_Arduino_Library.h"
VL53L1X distanceSensor ;
In my test program. this all works fine. But when I repeated the same process on my weather code, I get this:
weatherlcd1.ino:442:1: error: 'VL53L1X' does not name a type
The line it’s complaining about is where the distanceSensor object is defined. As far as I can tell, I typed all the names correctly. Why did this include work OK once but not twice? What am I doing wrong?
The compiler seems to be finding the library because I see this:
Building cpp file: src/SparkFun_VL53L1X_Arduino_Library.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=0.7.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../communication/src -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../hal/src/photon/api -I../hal/src/photon/include -I../hal/src/photon/wiced/security/BESL/host/WICED/ -I../hal/src/photon/wiced/security/BESL/include -I../hal/src/photon/wiced/security/BESL -I../hal/src/photon/wiced/security/BESL/crypto -I../hal/src/photon/wiced/WWD/include/ -I../hal/src/photon/wiced/platform/include/ -I../hal/src/photon/wiced/platform/GCC/ -I../hal/src/photon/wiced/security/BESL/supplicant/ -I../hal/src/photon/libraries/crypto -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -Isrc -I./libraries -Ilib/ITEADLIB_Nextion/src -Ilib/Adafruit_Sensor/src -Ilib/SparkFun_Serial_Graphic_LCD/src -Ilib/SparkFunPhant/src -Ilib/ThingSpeak/src -Ilib/Adafruit_AM2315/src -Ilib/SparkFun_Photon_Weather_Shield_Library/src -Ilib/Sunrise/src -Ilib/OneWire/src -I. -MD -MP -MF ../build/target/user/platform-6-msrc/SparkFun_VL53L1X_Arduino_Library.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DBOOTLOADER_SDK_3_3_0_PARTICLE -DPARTICLE_DCT_COMPATIBILITY -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=5 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,207 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\"" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++11 -c -o ../build/target/user/platform-6-msrc/SparkFun_VL53L1X_Arduino_Library.o src/SparkFun_VL53L1X_Arduino_Library.cpp
src/SparkFun_VL53L1X_Arduino_Library.cpp:42:6: warning: "ARDUINO" is not defined [-Wundef]
#if (ARDUINO >= 100)
src/SparkFun_VL53L1X_Arduino_Library.cpp:68:7: warning: "__MK20DX256__" is not defined [-Wundef]
#elif __MK20DX256__
src/SparkFun_VL53L1X_Arduino_Library.cpp:71:7: warning: "ARDUINO_ARCH_ESP32" is not defined [-Wundef]
#elif ARDUINO_ARCH_ESP32
I must be missing something here.
