[Solved] Use of c++ array of char arrays (char**) with Photon
Hello everyone!
i am trying to print out a char** array but I always get red flashing back.
void parseHeader (char * line) {
  static int len;
  static char * tok;
  static char ** call;
  int i=0;
  tok = strtok (line,"!?:=");
  while (tok != NULL)
    call[i]=tok;
    i++;
    Serial.write(tok);
    Serial.write(call[0]);
    tok = strtok (NULL, "!?:=");
I debugged the code above and seems to be the action of printing it.
Also tried to use pure printf() but photon compile without creating binaries.
What am I doing wrong?
You’re not allocating the call array so you’re overwriting random memory when you set call[i].
Something like this would work:
  const size_t MAX_CALLS = 10;
  int len;
  char * tok;
  char *call[MAX_CALLS];
  int i=0;
  while (tok != NULL && i < MAX_CALLS)
    call[i]=tok;
    Serial.write(tok);
    Serial.write(call[i]);
    i++;
WOW! Super fast reply!
Ouch :sweat_smile:. My bad…
Thank you very much for your help.
