Hi, long time no post.
Anyways, I’ve got an older CC3000 core that’s compiling with 0.5.0 firmware that I’m trying to run the following code snippet as part of my setup{}
if (WiFi.ready()) {
Particle.process();
Serial.print("Has Credentials:\t");
Serial.println(WiFi.hasCredentials());
Serial.println("Last 5 Cached WiFi networks:");
WiFiAccessPoint ap[5];
int found = WiFi.getCredentials(ap, 5);
Serial.println(found);
for (int i = 0; i < found; i++) {
Serial.print("ssid: ");
Serial.println(ap[i].ssid);
// security is one of WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA, WLAN_SEC_WPA2
Serial.print("security: ");
Serial.println(ap[i].security);
// cipher is one of WLAN_CIPHER_AES, WLAN_CIPHER_TKIP
Serial.print("cipher: ");
Serial.println(ap[i].cipher);
I mostly borrowed this code from the documentation and added a few lines to debug further: https://docs.particle.io/reference/firmware/photon/#getcredentials-
WiFi.hasCredentials() spits out “1”, but found = 0 in this example, so the loop doesn’t run.
I’ve manually set found = 5 to force the loop, but as you’d expect, there’s no meaningful output.
So, why do I appear to have credentials, but can’t iterate through them?
A few other notes; This core has been offline for many months, but appears to reach the cloud and update just fine. In it’s past use, it primarily only used a single SSID. I was looking to cache additional wireless credentials, but based on a few other posts concerning WiFi.setCredentials() I was leery about implementing this before I could use WiFi.getCredentials() to output successfully. I am able to use other WiFi.class functions in setup{} to output my core’s ip, etc.
I’m open to suggestions, including alternative means to cache additional SSIDs (via mobile app, CLI listen mode, etc).
