[SOLVED] setCredentials not saving WiFi credentials
Can anyone answer why WiFi.setCredentials() is not working for me (under firmware 0.4.9 and 0.5.0)?
I have researched the forums on this topic with no joy. It seems that this API is working for others.
The following code's purpose is to ensure that a default WiFi network "MySSID" is always loaded into the Photon. It only sets the network credentials if it is not loaded (so as to avoid flash wear).
SYSTEM_MODE(SEMI_AUTOMATIC);
    bool bHaveMyWiFi = false;
    char * szp = "????";
    delay(2000L);
    WiFiAccessPoint ap[5];
    int nFound = WiFi.getCredentials(ap, 5);
    for (int i = 0; i < nFound; i++)
        Serial.print("    SSID: ");
        Serial.print(ap[i].ssid);
        // Security
        switch(ap[i].security)
            case WLAN_SEC_UNSEC:
                szp = "NONE";
                break;
            case WLAN_SEC_WEP:
                szp = "WEP ";
                break;
            case WLAN_SEC_WPA:
                szp = "WPA ";
                break;
            case WLAN_SEC_WPA2:
                szp = "WPA2";
                break;
        Serial.print(" Security: ");
        Serial.print(szp);
        // Cipher
        szp = "????";
        switch(ap[i].cipher)
            case WLAN_CIPHER_AES:
                szp = "AES";
                break;
            case WLAN_CIPHER_TKIP:
                szp = "TKIP";
                break;
            case WLAN_CIPHER_AES_TKIP:
                szp = "TKIP";
                break;
        Serial.print(" Cipher: ");
        Serial.println(szp);
        // Check what WiFi networks are loaded
        if (strcmp("MySSID", ap[i].ssid) == 0)
            bHaveMyWiFi = true;
    }   // for ...
    if (!bHaveMyWiFi)
        // for hidden and offline networks on the Photon, the security cipher is also needed
        // Cipher options are WLAN_CIPHER_AES, WLAN_CIPHER_TKIP and WLAN_CIPHER_AES_TKIP
        WiFi.setCredentials(szp = "MySSID", "MyPASSWORD", WPA2, WLAN_CIPHER_AES);
        Serial.print("Setting WiFi ");
Here is the console output after running the program for the first time (which is expected):
SSID: RZONE Security: WPA2 Cipher: AES
Setting WiFi MySSID
Here is the console output after every reset (not expected, it is the same as the above - there should be no "Setting WiFi MySSID" - this indicates that the credentials were not set):
Setting WiFi MySSID
I note that network "MySSID" is not in existence.
I get the feeling that there might be a "gotcha" here.
Thanks in advance - @umd
It seems to be missing in the docs, but you need to have WiFi.on() (which SEMI_AUTOMATIC hasn’t) in order to have WiFi.setCredentials() do its job.
Update:
I’ve just added a Note about this in the docs.
@ScruffR, advice received with thanks (as per usual).
Happy to confirm case closed - works as expected once I included WiFi.on() prior to WiFi.setCredentials().
This now allows us to set up WiFi connections for specific projects.
Cheers - Harry
