[Solved] String.toUpperCase()
String.toUpperCase() seems not there on Spark Core. What should I use to convert entire String to upper case or lower case?
Seems like it is: http://docs.spark.io/firmware/#string-class-touppercase
How are you determining that it’s ā€˜not there’ ? :wink:
It is definitely there–it does its work ā€œin placeā€, that is, it does not return a value:
    String myStr = "foo";
    myStr.toUpperCase();
Thanks bko, it worked.
