Hello, all!
I have recently gotten my Particle Photon, and as a simple first project, I’m building an ambient light weather indicator with a few RGB LEDs, frosted acrylic, and a Photon. Physically, it’s all good. No issues there. Program-wise, I have the Photon partnered with IFTTT to poll the weather and send a quick blurb of the weather to the a SparkFunction. The spark function searches the string for certain key weather words and changes the LEDs according. Below, you’ll see my code.
int red = 3;
int green = 2;
int blue = 1;
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
Spark.function("weather", weatherLEDs);
Serial.print("Hello World\n");
void loop() {}
int weatherLEDs(String weather){
weather.toLowerCase();
Serial.print(weather);
if ((weather.indexOf("rain")>0) | (weather.indexOf("rainy")>0) | (weather.indexOf("showers")>0)) {
digitalWrite(blue, HIGH);
return 1;
if ((weather.indexOf("sunny")>0)) {
digitalWrite(red, HIGH);
digitalWrite(green, HIGH);
return 1;
if ((weather.indexOf("storms")>0) | (weather.indexOf("thunderstorms")>0) | (weather.indexOf("lightning")>0)) {
return 1;
else {return 0;}
The issue now is that the weather.toLowerCase() returns the exact same string it was handed, often with uppercase letters. I’ve been running a serial monitor and using curl along with phrases which should be giving me corresponding colors (e.g. “Rain” or “Scattered Thunderstorms”), but the output string always has upper case letters. I’ve checked the Arduino reference (it seems to be nearly universally applicable to .ino files, but if I should be using some other reference, please let me know) on toLowerCase() and my usage above is correct, but the results just aren’t there. Any ideas or insight? I’m moving over from mainly arduino tinkering, so I may have made some silly error for Particle about which I am unaware.
