My spark was working well before tonight. I made a few tweaks to surrounding hardware and after turning it back on, it booted up then shut off. I disconnected the spark from all other hardware and it still is having the same issue. It will turn on and breathe just fine with other simple apps, so I’m guessing there is code in mine that is crashing it but Im not quite sure what it is. I would really appreciate any insight anyone can provide. Thanks. Here is my app code.
int potVal = 0;
int finalPotVal = 0;
float hour = 3600000;
float wait = 0;
int load = 0;
int bed = 0;
int sensorPin = A0;
int potIn = A1;
int buttonPin = 2; // the number of the input pin
int flipSwitch = 4;
int buzzPin = 5;
int ledPin = 6; // the number of the output pin
int buttonState = 0;
int flipState = LOW;
int buzzState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000; // interval at which to blink (milliseconds)
RGB.brightness(0);
pinMode(buttonPin, INPUT);
pinMode(flipSwitch, INPUT);
pinMode(buzzPin, OUTPUT);
pinMode(ledPin, OUTPUT);
void beep(){
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (buzzState == HIGH)
buzzState = LOW;
else
buzzState = HIGH;
// set the LED with the ledState of the variable:
digitalWrite(buzzPin, buzzState);
buttonState = digitalRead(buttonPin);
flipState = digitalRead(flipSwitch);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
else {
// turn LED off:
digitalWrite(ledPin, LOW);
switch (digitalRead(2)) {
case 0:
potVal = analogRead(potIn);
finalPotVal = map(potVal, 0, 6000, 0, 16000);
if (finalPotVal >= 0 && finalPotVal < 400) {wait=hour*.3;digitalWrite(ledPin,HIGH);}
if (finalPotVal > 401 && finalPotVal < 850) {(wait=hour*.75);digitalWrite(ledPin,LOW);}
if (finalPotVal > 851 && finalPotVal < 1850) {(wait=hour*1);digitalWrite(ledPin,HIGH);}
if (finalPotVal > 1851 && finalPotVal < 2400) {(wait=hour*4);digitalWrite(ledPin,LOW);}
if (finalPotVal > 2401 && finalPotVal < 2800) {(wait=hour*4.5);digitalWrite(ledPin,HIGH);}
if (finalPotVal > 2801 && finalPotVal < 3300) {(wait=hour*5);digitalWrite(ledPin,LOW);}
if (finalPotVal > 3301 && finalPotVal < 3600) {(wait=hour*5.3);digitalWrite(ledPin,HIGH);}
if (finalPotVal > 3601 && finalPotVal < 3900) {(wait=hour*5.6);digitalWrite(ledPin,LOW);}
if (finalPotVal > 3901 && finalPotVal < 4200) {(wait=hour*6);digitalWrite(ledPin,HIGH);}
if (finalPotVal > 4201 && finalPotVal < 4340) {(wait=hour*6.25);digitalWrite(ledPin,LOW);}
if (finalPotVal > 4341 && finalPotVal < 4550) {(wait=hour*6.5);digitalWrite(ledPin,HIGH);}
if (finalPotVal > 4551 && finalPotVal < 4610) {(wait=hour*6.75);digitalWrite(ledPin,LOW);}
if (finalPotVal > 4611 && finalPotVal < 4705) {(wait=hour*7);digitalWrite(ledPin,HIGH);}
if (finalPotVal > 4706 && finalPotVal < 4830) {(wait=hour*7.25);digitalWrite(ledPin,LOW);}
if (finalPotVal > 4831 && finalPotVal < 4920) {(wait=hour*7.5);digitalWrite(ledPin,HIGH);}
if (finalPotVal > 4920 ) {(wait=hour*8);digitalWrite(ledPin,LOW);}
Serial.print(" Time Delay:");
//Serial.print(wait);
Serial.print(finalPotVal); //for testing actual pot val
Serial.print(" Button State:");
Serial.println(buttonState);
delay(100);
break;
case 1:
digitalWrite(6, HIGH);
delay(wait);
for(int x=0; x<500000; x++){
load = analogRead(sensorPin);
if(flipState==HIGH) {bed = 4000;}
else{bed = 950;};
if(load > bed) {(beep());
else{digitalWrite(buzzPin,LOW);}
Serial.print("Weight:");
Serial.print(load);
delay(10);
