Hey everyone.
I’ll try to keep this concise.
My goal: Photon 1 (TCP Client) needs to send 4 different integer values to Photon 2 (TCP Server).
The integer values all have an uint_8t range (0-255).
Basically I need help programming 4 integers into something that can be send over TCP connection and then the server should be able to process this data as those 4 integers. So far my code is able to send 1 integer quite reliably at a speed of <70ms (I disabled cloud connection).
So, any advice on how to package these integers into data (I’m assuming an array of "char"s) and then extract them back into 4 integers after the server has read this? The biggest question mark for me is that since the range is 0-255 the integers can either have 1, 2 or 3 digits and this can/will vary over time, so how can the server interpret this data correctly?
If anyone can point me into the right direction I’d really appreciate that!!
ps: I’m not the most experienced programmer
TCPClient does deal with binary data (sending and receiving) - no need to turn the values into decimal string representation of the number.
Try something like this
// buffer
uint8_t values[4];
//sending
client.write(values, 4);
// receiving
for(int i=0; client.available() && i<4; i++)
values[i] = client.read();
Can’t believe it’s that simple… Thank you so much, you’re a life/project-saver!
For people that want the code:
TCPServer:
TCPServer server = TCPServer(80);
TCPClient client;
uint8_t values[4];
uint32_t lastTime;
const char replymsg[60] = "TheInMsg and then a whole lot more characters than before";
// start listening for clients
server.begin();
// Make sure your Serial Terminal app is closed before powering your device
// Now open your Serial Terminal, and hit any key to continue!
while(!Serial.available()) Particle.process();
Serial.println(WiFi.localIP());
Serial.println(WiFi.subnetMask());
Serial.println(WiFi.gatewayIP());
Serial.println(WiFi.SSID());
void out(const char *s) {server.write( (const uint8_t*)s, strlen(s) ); client.stop();}
if (client.connected()) {
// echo all available bytes back to the client
for(int i=0; client.available() && i<4; i++){
Serial.println(values[i]);
client.read();
client.flush();
lastTime = millis();
while( millis()-lastTime < 5){}
out(replymsg);
} else {
// if no client is yet connected, check for a new connection
client = server.available();
Serial.println("Checking for connecctions");
TCPClient:
TCPClient client;
byte server[] = {192,168,0,160};
uint8_t values[4];
char inmsg[512];
bool complete;
uint32_t lastTime;
String myInStr;
values[0] = 255;
values[1] = 1;
values[2] = 0;
values[3] = 0;
void in(char *ptr, uint8_t timeout) {
int pos = 0;
unsigned long lastdata = millis();
while ( client.available() || (millis()-lastdata < timeout)) {
if (client.available()) {
char c = client.read();
ptr[pos] = c;
pos++;
//Serial.println("I received and read the response");
client.read();
void loop(){
complete = false;
while ((!complete) && (millis() - lastTime < 100)) {
if (client.connect( server, 80)) {
Serial.println("Writing values");
while ((!client.available()) && (millis() - lastTime < 500)) {
Particle.process();
//Serial.println("Waiting for a response");
}//wait for response
in(inmsg,10);//5-10 pure trial and error
myInStr =inmsg;
if (myInStr.indexOf(replymsg) >= 0) {
complete = true;
client.stop();
Serial.println("Stopping client");
client.stop();
Serial.println("Stopping client 2");
delay(1);
This works incredibly well and even with the cloud enabled I get a ridiculous speed that’s definitely below 100 milliseconds. Really awesome, I’ll have this going overnight and see if it can make it through till morning to check reliability.
