I received my Spark core last night. I spent two hours to add it to my account manually. Now the console shows the core, but I don’t see it in the list API response. Did I miss anything in the manual setup?
curl https://api.spark.io/v1/devices -d access_token=xxxx
“ok”: false,
“errors”: [
“arg.deviceID is empty”
curl https://api.spark.io/v1/devices/55ff74065075555353381887 -d access_token=xxxx
Not Found
I order the u.FL version and used a paper clip as the antenna. At first the core did not connect to wifi with a flashing green light. I then flashed the latest firmware via USB and manually added it to the console. The tinker app works great, but I can’t access the core via API calls…
By the way, the status of the core as shown in the console is “connected”.
