[SOLVED]Photon - reboot loop
Hi all.
New to all this so go easy on me! I’ve been building a project for a couple of weeks on a Photon and all has been going well. Unfortunately I turned it on today to deploy an application to it and it now appears to be stuck in a reboot loop.
All the lights are flashing so I have no idea what’s going on. Perhaps someone else will be able to decipher them:
I’ve tried pressing the reset button which doesn’t seem to help.
I’ve also tried doing a factory reset, but it just starts flashing yellow infinitely.
It’s connecting to the cloud each time it reboots as I can see lots of events for “device came online” in the Particle Dashboard. No other events though…
Any suggestions on what I should do would be hugely appreciated.
Rich
That an SOS code, highlighting specific errors. To get a clue of what they might indicate, have a look at the docs over here.
Well... See the following... https://docs.particle.io/guide/getting-started/modes/photon/#factory-reset
Let me know if that helped.
Perfect! Didn’t realise it was an SOS code - couldn’t understand why all the colours were flashing. Booted into safe mode then used the cloud IDE to deploy a basic app - all seems to be working again :smile:
