Hello everyone !
I require your help about a datalogger i am making with a Photon for an intern :
This datalogger measures some sensor values 10 times per hour (one measure published every 6 minutes then).
The specifications say that the console log will be used to visualize the last sensor measeurement via the Particle.publish() command.
But the console only displays the event that ARE published, not WERE published when the console was not opened.
i saw in the docs ( https://docs.particle.io/reference/firmware/electron/#particle-publish- ) :
Calling Particle.publish() when the device is not connected to the cloud will not result in an event being published. This is indicated by the return success code of false.
But my events are actually published, since my Photon is connected to the cloud, the problem is just that my console is not opened when the last publication is posted.
So, my question is : Can i display the last event (or events) published (when my console was not opened) when i open my console log ?
Your answers will help me a lot...Thank you !
side.
