My code includes the statement
int16_t x;
The compiler throws me an error
"‘int16_t’ does not name a type"
It does this even though my code includes stdint.h
I believe int16_t is a standard type listed in stdint.h
So why would the compiler complain?
I must be missing something here. Does anyone have any suggestions?
I guess this is not part of an .ino file, so you should #include "Particle.h"
Thanks for the suggestion ScruffR. I did as you suggested, but still got the same error message.
bko
4
I think you are going to have to tell us how you are compiling your code, and post at least the failing part of your code.
The int16_t type works fine for me.
I am compiling using the Particle web-based IDE.
https://build.particle.io/build/
Here is the code portion that triggers the error.
typedef struct {
int16_t x;
int16_t y;
int16_t z;
} LIS3DHSample;
The code is taken from the ASSETTRACKERRK library.
bko
6
Hi @fguptill
Stucts don’t always work well with the Wiring pre-processor used for Particle devices. Try adding this to the very top of the sketch:
#pragma SPARK_NO_PREPROCESSOR
You will then have to follow normal C/C++ rule for forward declaration like having function headers before you use the function etc.
Issue solved.
I inserted the following text as line 1 in my ino.
“// This #include statement was automatically added by the Particle IDE.”
And code compiles without errors.
ScruffR
8
Yup, that is one of these occasions where the Particle Wiring preprocessor creates confusion
