Built in types become unavailable when I move code to cpp file
I am experiencing some weirdness… I have 2 files foo.ino and bar.h using the Particle Dev IDE. Everything compiles fine until I move the implementation of one of my private methods from the .h file to a newly created .cpp file. The first error is ‘uint16_t has not been declared’ - which happens to be one of the args to my constructor in the .h file. There’s a long list of errors where I’m using other standard types also, the uint16_t just happens to be the first.
foo.ino
#include "bar.h"
Bar bar((const char[]){ 10, 1, 1, 1 }, 8080);
void setup() { }
void loop() { bar.doStuff(); }
bar.h
#ifndef _bar_
#define _bar_
class Bar
public:
    Bar(const char * host, uint16_t port) : host(host), port(port) { }
    void doStuff() { baz(); }
private:
    bool baz();
    const char * host;
    uint16_t port;
#endif
bar.cpp
#include "bar.h"
bool Bar::baz()
    return true;
As I mentioned, if I delete the cpp file and move the implementation of baz() to bar.h, everything works fine. Also, if I add #include <stdint.h> to the top of bar.h it compiles with the cpp file. While I can obviously work around this, I wouldn’t mind knowing:
  • why this is happening (or is it just me being pedantic)
  • am I doing something less than ideal by adding the stdint include to work around the problem
  • what should I be doing different, if anything
Oh yeah, and adding #pragma SPARK_NO_PREPROCESSOR to the top of my ino file doesn’t change anything, if that helps.
Many thanks
#include "Particle.h"
Try that
Works, as does adding the stdint include, but doesn’t really answer my question. I’m more concerned with why success turns to failure when the implementation is moved to a cpp file.
When you have a .ino file the Arduino preprocessor is enabled. This includes the default header files (Particle.h/application.h) and also creates forward declarations for functions implemented after they’re used.
When you use a .cpp file extension, you’re using a plain gcc C++ compiler, which does not have built-in header files, so you should
Ok… I’m still using the .ino file just so we’re clear. The issue arises simply by adding a .cpp file to the project.
No, the “issue” is that you moved your code from a .h file that was included after the implicitly added #include "Particle.h" which also makes the the definitions available to a .cpp file where these definitions don’t apply since .cpp files are not included into the main file but get compiled as seperate module.
Ah I see. Thanks for the explanation.
