[SOLVED] How to set user agent for http get
This code used to work but no longer does.
 request.hostname = "newsapi.org" ;
   request.port = 80;
   request.path = "/v1/articles?source=reuters&sortBy=latest&apiKey=keyRedacted"
    // The library also supports sending a body with your request:
    //request.body = "{\"key\":\"value\"}";
     // Get request
        Serial.println (" Connecting to news ...") ;
        http.get (request, response, headers) ;
Now I get this error:
{"status":"error","code":"userAgentMissing","message":"Please set your User-Agent header to identify your application. Anonymous requests are not allowed."}s":"error","code":"userAgentMissing","message":"Please set your User-Agent header to identify your app
Fair enough, but how do I do that? This post https://community.particle.io/t/http-get-response-code-1/25657/12 seems to be the same problem but adding
   http_header_t headers[] = {
    //  { "Content-Type", "application/json" },
    //  { "Accept" , "application/json" },
    {"User-Agent","ParticleHttpClient"},
    { "Accept" , "*/*"},
directly before setting request.hostname didn't work (code compiles and runs but still fails to get the data).
It is possible that the server you are connecting to requires a valid string in the User-Agent field, not just that it's present. See the User-Agent specification.
Another thing to test is to direct the request to a service like RequestBin so you can see exactly the headers that are being transmitted to make sure that's working correctly.
Good suggestions. First I tried pasting the entire URL into Firefox and it worked OK there. I got the user agent string Firefox was using and put that in my Photon code:
{"User-Agent","Mozilla/5.0 (X11; Linux x86_64; rv:128.0) Gecko/20100101 Firefox/128.0"},
Still returns -1. Anyway, this site: https://techflarestudio.com/how-to-use-news-api-with-examples/ claims you can put anything in the user agent field for newsapi.org.
So I tried it in RequestBin using "RequestBin" for the user agent. That did work - it returned status 200.
I then tried moving the user agent string to the init section of my code:
but that didn't work either. I'm mystified.
When you used RequestBin, did the User-Agent show up correctly in the request headers? The library code looks like it should be adding it, but that is a good thing to make sure of.
Good question. This is what it said (and the event has a green checkmark next to it):
steps.code{1}
$response{3}
status:200
headers{0}
body{8}
aboutPipedream is the fastest way to connects APIs. Build and run workflows with code-level control when you need it — and no code when you don't.
event_id:
2kZN7cnbmQrjrKVWvAuerFsTj8m
workflow_id:
p_ZJCVGlB
owner_id:
o_bLINRPJ
deployment_id:
d_n3sK8ja6
timestamp:
2024-08-12T18:22:52.580Z
inspect:
https://pipedream.com/@/p_ZJCVGlB
quickstart:
https://pipedream.com/quickstart/
Where does it show the headers?
For the record, here is a complete minimal example of how to use User-Agent in an http request. It's tested and working on the Photon,as of 09/03/24. I'm marking this as Solved.
#include <HttpClient.h>
// Include Particle Device OS APIs
#include "Particle.h"
#include "HttpClient.h"
// Let Device OS manage the connection to the Particle Cloud
SYSTEM_MODE(AUTOMATIC);
// Show system, cloud connectivity, and application logs over USB
// View logs with CLI using 'particle serial monitor --follow'
SerialLogHandler logHandler(LOG_LEVEL_INFO);
HttpClient http;
    { "User-Agent", "ParticlePhoton" },
    { NULL, NULL } // Terminate headers with NULL
http_request_t request;
http_response_t response;
// setup() runs once, when the device is first turned on
  // Put initialization like pinMode and begin functions here
    request.hostname = "newsapi.org";
    request.port = 80;
    request.path = "/v2/top-headlines?country=us&apiKey=myKey"; // Replace with your API key
  } // end setup
// loop() runs over and over again, as quickly as it can execute.
    http.get(request, response, headers);
    Serial.println(response.status);
    Serial.println(response.body);
    // Stop the loop after one request
    while (true);
  } // end loop
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
