[SOLVED]Hook up SHT1x with photon
Hi guys
I’m new-bee and try to hook a SHT10 temp/humidity sensor to Photon,I’m using the library from
peekay123 and hook up as instructed , the demo compiled and the firmware updated, unfortunately the reading of the sensor is garbage, it seems like that it doesn’t connect to photon at all because even I pull out the sensor the reading is identical from photon. is anyone can help? that would be great appreciated .
IMG_0026.JPG<img src="//cdck-file-uploads-us1.s3.dualstack.us-west-2.amazonaws.com/flex026/uploads/particle/original/2X/9/97da8a1b0d3cc57bd7b0ea551027abf2749343a5.JPG"
Seems as though you’re missing a common ground. Double check that :slight_smile:
one simple and stupid mistake cost my the whole day, thanks done! sleeptime :joy:
Special thank to peekay123 for the SHT1X library, Moors7; great appreciated to point out my silly mistake, thanks again
