Hi everyone.
As of last night, it seems that our Photons have been unable to connect to the Particle API or accept calls to firmware functions via the Particle API. Normally we interact with our devices using the following POST request: https://api.particle.io/v1/devices/<device_id>/motiEvent/?access_token=<access_token> where <device_id> and <access_token> are replaced by a specific device id and our access token respectively. In the past, we could expect a valid and rapid response. As of last night, POST requests to this URL will instead return the following to our server logs:
This call is no longer working, but calling the API for a status of our devices show that they are indeed connected and have the ‘motiEvent’ function accessible, which we are calling via the Particle API:
Has anybody experienced a similar problem? Our code base did not change over the last few days, so I am unsure what changed to cause this to stop working all of a sudden.
I appreciate any help.
Steven Mazliach
Software Developer
MOTI
