SOLVED - Firmware 0.4.3 local build failing to link with error sbrkr.c:(.text._sbrk_r+0xc): undefined reference to `_sbrk'
The following is a simple app that compiles fine with the WebIDE but fails to link when compiled locally.
Anyone seen and/or have a solution?
 *  Copyright (c) 2015 Particle Industries, Inc.  All rights reserved.
 * This library is free software; you can redistribute it and/or
 * modify it under the terms of the GNU Lesser General Public
 * License as published by the Free Software Foundation, either
 * version 3 of the License, or (at your option) any later version.
 * This library is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 * Lesser General Public License for more details.
 * You should have received a copy of the GNU Lesser General Public
 * License along with this library; if not, see <http://www.gnu.org/licenses/>.
 #include "application.h"
	 Serial.begin(115200);
	  while (!Serial.available());
	  Serial.print("Initializing SD card...");
/* executes continuously after setup() runs */
    Serial.print(Time.timeStr().c_str());
Found the answer in another thread
