[SOLVED] Electron always goes to listening mode, when trying to "run offline"
The thing is that I am trying to run my electron offline to safe data while debugging, so I enter SYSTEM_MODE(SEMI_AUTOMATIC); above my code, and in the setup I put Particle.disconnect;
this works fine for the Photon , it simply breaths white and runs the code (offline) but when I put the same code to my electron it always tries to connect, I took the SIM out of the slot so it would not be connecting, and then it blinks blue (listening mode) and if I put the SIM in the slot then it simply connects, (which is should not do)
this is my test code
SYSTEM_MODE(SEMI_AUTOMATIC); // to be able to put photon/electron in offline mode
//SYSTEM_MODE(MANUAL);
void setup(){
Particle.disconnect();
//Cellular.off();
pinMode(D7,OUTPUT);
int i;
i++;
digitalWrite(D7, !digitalRead(D7));
delay(4500);
Serial.println(i);
delay(500);
// System.sleep(SLEEP_MODE_DEEP,5,SLEEP_NETWORK_STANDBY); //Uses lots of data
//System.sleep(D3, RISING, 3, SLEEP_NETWORK_STANDBY);
Just if anyone else runs into this problem… The solution was to update the firmware on my electron, it all works fine now
I’m glad you were able to resolve this. Thank you for being patient!
