[SOLVED] Can I apply 5V to the RST pin?
I would like to use an external device to reset my Electron but I only have access to 5V digital pins on that device.
Is the RST pin on the Electron 5V tolerant ?
I cant find anything about it in the data sheet
https://docs.particle.io/datasheets/electron-datasheet/
SOLUTION: No, you cannot. Use a voltage divider to step down 5v to 3.3v
I wouldn’t thinks so, since it has an internal pull-up to 3.3V which is an exclusion factor on the otherwise 5V tolerant GPIOs.
You’d permanently feedback from your 5V signal to the 3.3V rail via the pull-up resistor.
That make sense. I guess I could solve this by adding a voltage divider.
That should work.
What kind of signal pin are you dealing with? If it’s a GPIO of some sort (like from an Arduino) you could have it high-z and only got to output LOW when you want to reset.
