SmartBBQ: WiFi controlled 4 probe BBQ controller with blower output
Hi everyone. So I went through the process or building this project. I’m building 3 units to give to some people as well as allow me to learn from this all. After building it and powering on two of the builds, I am getting some interesting numbers. I have the ET732 Food and BBQ probes.
Without probes inserted, the display reads around 300. With one or more probes inserted, it reads 900-1000. Is there a reason this is happening? I’ve gone over the boards several times and everything seems to be soldered in correctly. Would be great to find out if anyone’s experienced this before.
Thanks in advance!
Have you tried an SHT1x? Temp and humidity up to 264F. I have seen it rated up to 308F. Available for about $5 on AliExpress.
