Hi
I have an issue with the SystemSleepMode::STOP
and wake-up on usart
and duration
with an electron. When the electron is woken up by UART the second character when reading from UART is missing. So when sending ‘12345’ from a terminal to wake-up the electron, then my firmware on the electron receives ‘1345’!
SystemSleepConfiguration config;
config
.mode(SystemSleepMode::STOP)
.duration(10s)
.usart(Serial1);
auto result = System.sleep(config);
This only happens when both are set as wake-up usart
and duration
. When only usart
is used all characters are received.
config
.usart(Serial1);
The GitHub - bittailor/Particle-UartWakeupIssue contains a full example that reproduces the issue. There is also a small node.js test script to send strings/commands to the electron and compare what it receives.
I tried it with DeviceOS versions 3.3.1, 3.30, 2.3.1, the issue is always the same.
Is this a known issue?
Or is it not possible to use usart
and duration
togther as wake-up trigger?
Or is there another issue with my code?
Thanks for any advice.
Regrads Franz
Example output of the test program that shows the issue.
$> npm test
> uart-wakeup-issue-test@1.0.0 test
> node test.js
** Send first two commands
send> 12345
send> 98765
uart> 0000001648 [app] INFO: Uart cli handle command => '1345'
recv> 1345
uart> 0000001648 [app] INFO: Uart cli handle command => '98765'
recv> 98765
** Wait until asleep again
uart> 0000006648 [app] INFO: Go to sleep [2]
** Send second two commands
send> HelloWorld
send> GoodBye
uart> 0000006663 [app] INFO: Uart cli handle command => 'HlloWorld'
recv> HlloWorld
uart> 0000006666 [app] INFO: Uart cli handle command => 'GoodBye'
recv> GoodBye
Missmatch on 0:
send: 12345
recv: 1345
Missmatch on 2:
send: HelloWorld
recv: HlloWorld
