Sleep after publish?
I would like to send my Photon to sleep after it has published a message. The problem is that the dashboard never receives my message.
My loop code:
// Read the volatge of the LiPo
float cellVoltage = batteryMonitor.getVCell();
// Read the State of Charge of the LiPo
float stateOfCharge = batteryMonitor.getSoC();
// Send the Voltage and SoC readings over serial
Serial.println(cellVoltage);
Serial.println(stateOfCharge);
// wait for the cloud connection to be connected or timeout after 10 seconds
    if (waitFor(Particle.connected, 10000)) {
        bool sent = Particle.publish("Data", String::format("voltage=%.2f;charge=%.0f"), cellVoltage, stateOfCharge)); //data,name=Maraiah internal=29.5,external=13.3 1434055562005000038
        Particle.process();
        if(sent == true){
            System.sleep(pin, RISING, sleep);
I found the hint with Particle.process(); here but it does not seem to work for me. I don’t like to use a delay because it blocks my code.
The if(sent == true) does not work either.
Without sleep everything works fine.
Is there a new solution for the 0.4.9 firmware?
Does this build at all?
The parentheses in this statement don’t seem to match up.
Another option to make sure your publish got delivered is to self-subscribe and place the sleep command into the subscribe handler.
BTW: The return value of Particle.publish() does not tell anything about the actual publication but only if the command has a chance to get executed at all.
Thanks for your reply!
It should be:
bool sent = Particle.publish("Data", String::format("voltage=%.2f;charge=%.0f", cellVoltage, stateOfCharge));
I have shortened my Particle.publish to make it easier to read and forgot the bracket.
I’ll try to self-subscribe and report back :smile:
Another thing you might consider is that you are not alone there and Data is a rather ubiquitous term, so you might receive events from others who have also used such an all but unique event name :wink:
You should either go for a less common term or send as PRIVATE (or both).
Had the same problem on the previous firmware, ended up doing both process and delay, less than ideal though.
Particle.publish("log", "Occu", 60, PRIVATE);
delay(1000);
Particle.process();
I am now using the code from here to subscribe to my sleep event and so far it works reliable. The only thing I have changed is that I added
canSleep = false;
before System.sleep because the Photon does not reset when it goes to sleep.
It takes 10 seconds from the device came online event to the device offline event.
