I adapt “wake on move” by including GPS and reduce state. But when I taste it, nothing publish. I can see nothing appear on thing speak even particle log.
Here is a part of it.
case SLEEP_STATE:
Particle.disconnect();
delay(500);
if(t.readXYZmagnitude() >= accelThreshold ){
Particle.connect();
delay(500);
awake = ((t.clearAccelInterrupt() & LIS3DH_INT1_SRC_IA) != 0);
Serial.println(t.readXYZmagnitude());
t.updateGPS();
state = PUBLISH_STATE;
else{
state = SLEEP_WAIT_STATE;
break;
case PUBLISH_STATE:
if (Particle.connected()) {
// The publish data contains 3 comma-separated values:
// whether movement was detected (1) or not (0) The not detected publish is used for battery status updates
// cell voltage (decimal)
// state of charge (decimal)
delay(10000);
float lat = t.readLatDeg();
float lon = t.readLonDeg();
char data[32];
float cellVoltage = batteryMonitor.getVCell();
float stateOfCharge = batteryMonitor.getSoC();
snprintf(data, sizeof(data), "%d,%.02f,%.02f", awake, cellVoltage, stateOfCharge);
String pubGPS = String::format("%f,%f",lat,lon);
// String pubAccel = String::format("%d,%d,%d",t.readX(),t.readY(),t.readZ());
Particle.publish(eventName, data, 60, PRIVATE);
// Particle.publish("Accelerometer_wake",pubAccel, PRIVATE);
while(lat == 0.0){
delay(10000);
Particle.publish("GPS_wake",pubGPS, PRIVATE);
delay(5000);
stateTime = millis();
else {
// Haven't come online yet, let it oniline
Particle.connected();
break;
