Setup WiFi on Photon without using iOS Setup Library
OK, thats great. But not a great user experience for customers! I would need to explain that the process will seem broke, but actually works. So what we really need is the solution where an claimed device can be (re) set with Wifi.
To set the device into listening mode - I presume you can set the RST low for 3 seconds?
