setClockDivider() does not work
I am unable to change the SPI clock rate regardless of what parameter i use for setClockDivider().
Code is below.
int CS = D0;
pinMode(CS,OUTPUT);
digitalWrite(CS, HIGH );
// Prove to me that this latest example has been
// downloaded
Serial1.begin(115200);
Serial1.println("SPI Test 0.5");
//MSBFIRST
//LSBFIRST
SPI.setBitOrder(LSBFIRST);
//SPI_CLOCK_DIV2
//SPI_CLOCK_DIV4
//SPI_CLOCK_DIV8
//SPI_CLOCK_DIV16
//SPI_CLOCK_DIV32
//SPI_CLOCK_DIV64
//SPI_CLOCK_DIV128
//SPI_CLOCK_DIV256
SPI.setClockDivider(SPI_CLOCK_DIV256);
//SPI_MODE0
//SPI_MODE1
//SPI_MODE2
//SPI_MODE3
SPI.setClockDivider(SPI_MODE0);
// initialise it
SPI.begin();
// Bring my CS pin low
digitalWrite(CS, LOW );
// Send some data
SPI.transfer(0xa5);
// Bring my CS pin high
delay(10);
Spark Team, any ideas here on this. I am ata stand still with this one until i can slow the clock rate down.
Have you tried calling all the setup procedures after SPI.begin()?
SPI.begin();
That works just fine for me. How are you checking what speed the SPI bus is running at?
yes. same result. I am using a scope to check it.
Have you tried moving it all from void setup to void loop?
The command for setting the SPI mode is SPI.setDataMode(SPI_MODE0). With the code as it is, you are calling setClockDivider twice and the second call sets an incorrect value.
Also, as @timb indicated, your SPI.set commands should be in setup(). :smile:
