setChargeVoltage Command with Solar Panel with battery system
This post explains how to use it. Note that the reason it's not set higher is that the Electron does not include a battery temperature sensor. The default charge voltage is appropriate across the operating temperature range.
If you set the charge voltage higher, make sure you don't exceed the safe charging voltage based on temperatures, especially if the temperature will exceed 45°C.
