Set system time without Particle Cloud?
I want to run a simple NTP client on my Argon and use the delivered time as system time. Is it possible to set the system time from the NTP time (in the best case to load the NTP time as value for the RTC of the Argon)?
Thanks and greetings
You can use Time.setTime()
