Does anyone know the ARM equivalent for UCSR0A? The following code is from a Arduino library and everything works with it except the UCSR0A.
if ((UCSR0A & 0b01100000) != 0b01100000){ // Wait for TX data to be sent
Serial1.flush();
Serial1.flush();
@Spyke Looks like you need to wait until the transmit is done, and not a second later… bit 6 is TX complete and bit 5 is TX data register empty.
STM32 has this function that should help… I wrapped it up in a helper function… you can use it raw if you want:
int Serial1TXcomplete(void)
// Check if the USART Transmission is complete
if(USART_GetFlagStatus(USART2, USART_FLAG_TC) != RESET)
return 1; // Complete
else
return 0; // Not Complete
You can use it like this…
Serial1.print("paragraphs and paragraphs of text!!!!!!!!!!!!!!!!!!!");
while( !Serial1TXcomplete() ) {
// Sit here and do nothing...
// don't bother calling Serial1.flush(); because it's not implemented yet.
I didn’t test this, but it’s almost too easy not to work so let me know if it does please
It works fine thanks!
