As I understand the STM32 datasheet the default setup of PA0 and PA1 (Core A0/A1) after reset is to act as CTS/RTS pins for USART2, so just the ones that work together with RX/TX on the Core.
Is this behaviour kept intact after Core power up - as long there was no call for pinMode() on one of these?
And would Serial class support flow control, if A0/A1 are set up as CTS/RTS?
The reason why I ask is, that I’m having difficulties to get stable communication between my Core and an Roving Networks RN41 Bluetooth module when just using RX/TX (RTS/CTS bridged on the RN41 as suggested in RN datasheet).
