Hi, can someone help me understand why my Serial.println statement in Setup() won’t output to the serial port (I’m using TeraTerm v.4.98). Inside the Void loop I can get printf statements to work. I’m using an Electron 0.7.0 OS. Thanks
SYSTEM_MODE(MANUAL);
delay(1000);
Serial.println("I'm printing just fine");
are you sure that teraterm is connected to the device in the 1 second delay? Try waiting for the serial port to connect or you press a key to continue like.
while(!Serial.available()){};
Thanks for the suggestion. I made the chnage, but I’m still not seeing the Serial.println statement in TeraTerm. Here’s the updated code.
Update: the while statement did help and the Serial.println instructions are showing up in TeraTerm.
However, this solution really doesn’t address the underlying issue: why can’t TeraTerm capture the serial output in Setup()?
Are there any other methods (or terminal programs) or settings that I can use to address this?
It may be because you have just set up the serial port; I don’t think the computer could open a virtual COM port until it has been setup.
Also, try using waitUntil(Serial.isConnected());
If that doesn’t work, I would add like a delay(5000) before you try to print) to see if that makes a difference.
