Hello,
I am using Xenon as a Standalone device. I want to see the DHT22 data on CLI Serial monitor. No data printed at all. I checked the connections. I thought it was the cable and changed it. I am using the example code of PietteTech library. The code compiled and flashed successfully. Have you ever faced this kind of issue? Can you please share your experiences? I am adding a CLI photo that I am facing.
If you need any more information I will do my best to provide. Thank you for your time reading.
