For a while I thought you needed to use the spark_core.inf driver for COM and Zadig for DFU, but later I found out Zadig works for COM and DFU. EDIT: and then later I realized you really do need both! lol.
The problem with port already being in use is because your Core is sending data to the PC already… but you can’t open your serial port until your code runs the Serial.begin(9600); line…
The work around is this little piece of code:
Before your Core connects to the Cloud, make sure your Serial Terminal software is closed.
pinMode(D7,OUTPUT);
digitalWrite(D7,HIGH); // Light the onboard LED so you know it's time to open your Serial Terminal
Serial.begin(9600);
while(!Serial.available()); // wait here for user to press ENTER in Serial Terminal
digitalWrite(D7,LOW);
Serial.println("Weeeeeeeeeeeeeeeeeee!");
delay(1000);
You have about 10-15 seconds before this will kick your core off the cloud, so be quick. You also have to do the above process if you want to reflash your device over the air from the web IDE, because it will be stuck in the setup() and not able to receive a new program until you connect your serial terminal properly.
In Putty, make sure you are using Serial under the Session tab
Not the Connections tab… or it will DING at you. I learned that the hard way… thanks to @Dave
