Sorry for long post ![]()
I and Talybin are trying to identify a potential bug with Serial, first char in first message is always garbage. See Issue #682.
as example following code on Photon:
unsigned long lastTime = 0;
Serial1.begin(9600);
unsigned long now = millis();
if (lastTime == 0 || ((now - lastTime) > 5000)){
Serial1.println("!");
lastTime = now;
give this output in Putty:
â–’!
We think reason is that there is copy paste error in firmware, there is no memset for tx_buffer, so that the reason for garbage char in first message.
So I trying to resolve it in firmware to see if it fixes this problem.
I install all depecies needed according too Particle.io firmware
after that i use
git clone https://github.com/spark/firmware.git
cd firmware
git checkout latest
Then open files in downloaded firmware and edit copypaste error from Issue #682 so we do memset both for rx and tx buffer.
hal/src/core/usart_hal.c#L120
hal/src/core/usart_hal.c#L215
hal/src/stm32f2xx/usart_hal.c#L148-L149
hal/src/stm32f2xx/usart_hal.c#L263-L264
Than I switch to modules folder, connect Photon in DFU-mode and run
make PLATFORM=photon clean all program-dfu
so photon receives changed fixed firmware. No errors received and firmware are loaded in photon.
Then under user/applications I create a folder test and create file test.cpp :
#include "application.h"
lastTime = now;
Then i change to main folder and run
make PLATFORM=photon APP=test
make PLATFORM=photon APP=test program-dfu
In output i receive
but when i push reset i receive
â–’!
My question is, do I update photon firmware right or do i make mistake somewhere?
If I do correct firmware update, can it be somewhere else reason for garbage char is? Someone who can help us find it?
@changed blink to test
