I’m trying to send commands and receive some stats over BLE to a web page.
The sending is working fine, but cant work out how to get stats back, for a char or a string.
I’m using this example for control https://github.com/NickDST/BLEwithXenonAndChrome
In the HTML it does touch on reading values.
//This is unused, but you can use this to read values from the Particle
async readSomething() {
const service = await this.device.gatt.getPrimaryService("4677062c-ad02-4034-9abf-9858177xxxxx");
const characteristic = await service.getCharacteristic("dc13b36a-3499-46b0-ac11-5ac0173xxxxx");
await characteristic.readValue();
here is the device code:
// Variables for keeping state
typedef struct {
uint8_t light;
uint8_t light2;
} led_level_t;
// Static level tracking
static led_level_t m_led_level;
int led1 = A3;
int led2 = D7;
int num = 1;
bool lightStatus = false;
const char* serviceUuid = "4677062c-ad02-4034-9abf-98581772427c"; //service
const char* light = "dc13b36a-3499-46b0-ac11-5ac0173c4cc5"; //red char
const char* light2 = "26f260de-0b93-4352-baa3-56b8be1e606a"; //green char
//Static function for handling Bluetooth Low Energy callbacks
static void onDataReceived(const uint8_t* data, size_t len, const BlePeerDevice& peer, void* context) {
// Sets the global level
if( context == light ) {
m_led_level.light = data[0];
if( context == light2 ) {
m_led_level.light2 = data[0];
// RGB.control(true);
// RGB.control(m_led_level.green);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// Set the RGB BLE service
BleUuid rgbService(serviceUuid);
BleCharacteristic redCharacteristic("lightValue", BleCharacteristicProperty::WRITE_WO_RSP, light, serviceUuid, onDataReceived, (void*)light);
BleCharacteristic blueCharacteristic("lightValue", BleCharacteristicProperty::WRITE_WO_RSP, light2, serviceUuid, onDataReceived, (void*)light2);
// Add the characteristics
BLE.addCharacteristic(redCharacteristic);
BLE.addCharacteristic(blueCharacteristic);
// Advertising data
BleAdvertisingData advData;
// Add the RGB LED service
advData.appendServiceUUID(rgbService);
// Start advertising!
BLE.advertise(&advData);
if(m_led_level.light){
digitalWrite(led1, HIGH);
Particle.variable("light1", "On");
} else {
digitalWrite(led1, LOW);
Particle.variable("light1", "Off");
if(m_led_level.light2){
digitalWrite(led2, HIGH);
Particle.variable("light2", "On");
} else {
digitalWrite(led2, LOW);
Particle.variable("light2", "Off");
delay(500);
I’ve experimented with
voltageInputCharacteristic.setValue(<c_v_input); but just don’t really get it.
Ive searched but can find any simple examples to send data to a webpage other then https://rickkas7.github.io/ble-powersource/ which seems to be two totally different connection methods…
Anyone have any pointers?
