Hey Particle community,
I’m in the middle of a student project where I want to change the state of some Philip HUE lamps with our Particle Photon. I have some very basic understanding of coding and this project has proven difficult. I’m trying to adapt the code seen here: http://www.makeuseof.com/tag/control-philips-hue-lights-arduino-and-motion-sensor/
Since a lot of the code in that example is calling libraries that doesn’t exist on the Photon, I would be eternally grateful if someone could take the time to explain what I need to do to adapt it. We’re implementing the trigger to be a sound sensor, so the part that revolves around his motion sensor is abundant.
Here’s the code:
Talking to Hue from an Arduino
By James Bruce (MakeUseOf.com)
Adapted from code by Gilson Oguime. https://github.com/oguime/Hue_W5100_HT6P20B/blob/master/Hue_W5100_HT6P20B.ino
#include <SPI.h>
#include <Ethernet.h>
// Hue constants
const char hueHubIP[] = "192.168.1.216"; // Hue hub IP
const char hueUsername[] = "newdeveloper"; // Hue username
const int hueHubPort = 80;
// PIR
int pir = 2;
boolean activated = false;
// Hue variables
boolean hueOn; // on/off
int hueBri; // brightness value
long hueHue; // hue value
String hueCmd; // Hue command
unsigned long buffer=0; //buffer for received data storage
unsigned long addr;
// Ethernet
byte mac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 }; // W5100 MAC address
IPAddress ip(192,168,1,2); // Arduino IP
EthernetClient client;
Setup
Ethernet.begin(mac,ip);
pinMode(pir,INPUT);
delay(2000);
Serial.println("Ready.");
if(digitalRead(pir) == 1){
Serial.println("activated");
// A series of four sample commands, which colour fades two lights between red and pink. Read up on the Hue API
// documentation for more details on the exact commands to be used, but note that quote marks must be escaped.
String command = "{\"on\": true,\"hue\": 50100,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
setHue(1,command);
command = "{\"on\": true,\"hue\": 65280,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
setHue(2,command);
command = "{\"hue\": 65280,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
setHue(1,command);
command = "{\"hue\": 50100,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
setHue(2,command);
// so we can track state
activated = true;
else{
activated = false;
Serial.println("deactivated");
//was activated, so send a single off command
String command = "{\"on\": false}";
setHue(1,command);
setHue(2,command);
/* setHue() is our main command function, which needs to be passed a light number and a
* properly formatted command string in JSON format (basically a Javascript style array of variables
* and values. It then makes a simple HTTP PUT request to the Bridge at the IP specified at the start.
boolean setHue(int lightNum,String command)
if (client.connect(hueHubIP, hueHubPort))
while (client.connected())
client.print("PUT /api/");
client.print(hueUsername);
client.print("/lights/");
client.print(lightNum); // hueLight zero based, add 1
client.println("/state HTTP/1.1");
client.println("keep-alive");
client.print("Host: ");
client.println(hueHubIP);
client.print("Content-Length: ");
client.println(command.length());
client.println("Content-Type: text/plain;charset=UTF-8");
client.println(); // blank line before body
client.println(command); // Hue command
client.stop();
return true; // command executed
else
return false; // command failed
/* A helper function in case your logic depends on the current state of the light.
* This sets a number of global variables which you can check to find out if a light is currently on or not
* and the hue etc. Not needed just to send out commands
boolean getHue(int lightNum)
client.print("GET /api/");
client.println(" HTTP/1.1");
client.println("Content-type: application/json");
client.println();
if (client.available())
client.findUntil("\"on\":", "\0");
hueOn = (client.readStringUntil(',') == "true"); // if light is on, set variable to true
client.findUntil("\"bri\":", "\0");
hueBri = client.readStringUntil(',').toInt(); // set variable to brightness value
client.findUntil("\"hue\":", "\0");
hueHue = client.readStringUntil(',').toInt(); // set variable to hue value
break; // not capturing other light attributes yet
client.stop();
return true; // captured on,bri,hue
else
return false; // error reading on,bri,hue
