Segger Flasher Basic Tutorial
I just purchased a Segger Flasher Compact programmer and I was wondering if anyone had a basic tutorial to program devices with it? I saw the Particle SWD documentation, but there is nothing specific for using the Segger platform. There are tons of options and it would be great to see what a basic setup would be for the Restor Hex files provided by Particle.
There are options to erase the chip before programming and I have no idea if this erase function completely wipes out the device ID, keys etc.
So any basic setup help would be appreciated!
I want to eventually set this programmer up to be a stand-alone unit for our production process.
From the Segger settings, there are sectors that can be selected. I am not sure what sectors should be selected from below to avoid erasing or programming over the below list of items.
  • The flash procedure described here does not erase configuration. The following are not erased:
    • Emulated EEPROM contents
    • Device Keys
    • Gen 2 Wi-Fi credentials, 6-character identifier used in the default SSID, and antenna configuration
    • Gen 3 Wi-Fi credentials, APN settings, antenna, and SIM selection configuration
    • Anything else in the DCT
    • Gen 3 flash file system contents
For Gen 3, you can erase the entire nRF52840 internal flash and none of the things you listed will be erased. The DCT and EEPROM are just files in the flash file system, and the flash file system is on the external flash. Doing a chip erase and programming the entire chip is super fast with the Segger, like 7 seconds to program the bootloader, soft device, Device OS, and user firmware.
For Gen 2, compare the memory map in the datasheet with the sector addresses. If you do not erase the two DCT sectors (one is 16K and one is 64K) you’ll keep the Wi-Fi credentials, 6-character identifier used in the default SSID, and antenna configuration.
There seems to be a setting to target the RAM also. Is there anything on there that could be affected?
There’s nothing permanent in the RAM.
The device restore hex and custom hex files are great for initial flashing of a device, especially on the STM32.
On STM32, the DCT sits between the bootloader and Device OS. Since hex files are sparse, they skip over the DCT so you don’t overwrite your device keys and such when flashing a hex file by SWD/JTAG.
Also the hex file includes the address to flash to, which is way less error-prone than making sure you’ve set the load address correct in your SWD/JTAG programmer and using a bin file.
Thanks for the info.
I am trying to program the nrf52840 Boron and there is a sample init sequence for a nRF51822 below. Do you know if there is a sample init sequence for the nRF 85840 somewhere?
You shouldn’t need to do any of that to flash an nRF52840. You might also want to look into using nrfjprog. It’s described here and it makes it super easy to program a Gen 3 device using the Segger J-Link.
It’s literally:
nrfjprog -f NRF52 --program boron.hex --chiperase --reset
It runs in 7 seconds. It’s magic.
I’ll check that out, the device that I have is the Flasher Compact that I want to set up that doesn’t require a computer. I flashed a device with restore and it took 22.7 seconds. Do you have any thoughts what could be done to speed up the programming?
Below is the logging with the programming.
Auto programming target (703278 bytes, 6 ranges) ...
 - Connecting ...
  - Connected successfully
 - Checking if selected data fits into selected flash sectors.
 - Start of preparing flash programming
 - End of preparing flash programming
 - Start of determining dirty areas in flash cache
 - End of determining dirty areas
 - CPU speed could not be measured.
 - Start of erasing sectors
 - Blank checking 0x00000000 - 0x0001FFFF
 - Erasing range 0x00000000 - 0x0001FFFF ( 32 Sectors, 128 KB)
 - Blank checking 0x00020000 - 0x00026FFF
 - Erasing range 0x00020000 - 0x00026FFF (  7 Sectors, 28 KB)
 - Blank checking 0x00030000 - 0x0004FFFF
 - Erasing range 0x00030000 - 0x0004FFFF ( 32 Sectors, 128 KB)
 - Blank checking 0x00050000 - 0x0006FFFF
 - Erasing range 0x00050000 - 0x0006FFFF ( 32 Sectors, 128 KB)
 - Blank checking 0x00070000 - 0x0008FFFF
 - Erasing range 0x00070000 - 0x0008FFFF ( 32 Sectors, 128 KB)
 - Blank checking 0x00090000 - 0x000A5FFF
 - Erasing range 0x00090000 - 0x000A5FFF ( 22 Sectors, 88 KB)
 - Blank checking 0x000B4000 - 0x000B7FFF
 - Erasing range 0x000B4000 - 0x000B7FFF (  4 Sectors, 16 KB)
 - Blank checking 0x000D4000 - 0x000D4FFF
 - Blank checking 0x000F4000 - 0x000FFFFF
 - Erasing range 0x000F4000 - 0x000FFFFF ( 12 Sectors, 48 KB)
 - Blank checking 0x10001000 - 0x10001FFF
 - Erasing range 0x10001000 - 0x10001FFF (  1 Sector, 4 KB)
 - End of erasing sectors
 - Start of flash programming
 - Programming range 0x00000000 - 0x00007FFF (  8 Sectors, 32 KB)
 - Programming range 0x00008000 - 0x0000FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00010000 - 0x00017FFF (  8 Sectors, 32 KB)
 - Programming range 0x00018000 - 0x0001FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00020000 - 0x00026FFF (  7 Sectors, 28 KB)
 - Programming range 0x00030000 - 0x00037FFF (  8 Sectors, 32 KB)
 - Programming range 0x00038000 - 0x0003FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00040000 - 0x00047FFF (  8 Sectors, 32 KB)
 - Programming range 0x00048000 - 0x0004FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00050000 - 0x00057FFF (  8 Sectors, 32 KB)
 - Programming range 0x00058000 - 0x0005FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00060000 - 0x00067FFF (  8 Sectors, 32 KB)
 - Programming range 0x00068000 - 0x0006FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00070000 - 0x00077FFF (  8 Sectors, 32 KB)
 - Programming range 0x00078000 - 0x0007FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00080000 - 0x00087FFF (  8 Sectors, 32 KB)
 - Programming range 0x00088000 - 0x0008FFFF (  8 Sectors, 32 KB)
 - Programming range 0x00090000 - 0x00097FFF (  8 Sectors, 32 KB)
 - Programming range 0x00098000 - 0x0009FFFF (  8 Sectors, 32 KB)
 - Programming range 0x000A0000 - 0x000A5FFF (  6 Sectors, 24 KB)
 - Programming range 0x000B4000 - 0x000B7FFF (  4 Sectors, 16 KB)
 - Programming range 0x000D4000 - 0x000D4FFF (  1 Sector, 4 KB)
 - Programming range 0x000F4000 - 0x000FBFFF (  8 Sectors, 32 KB)
 - Programming range 0x000FC000 - 0x000FFFFF (  4 Sectors, 16 KB)
 - Programming range 0x10001000 - 0x10001FFF (  1 Sector, 4 KB)
 - End of flash programming
 - Flash programming performed for 6 ranges (716800 bytes)
 - 0x0000 - 0x26FFF ( 39 Sectors, 156 KB)
 - 0x30000 - 0xA5FFF (118 Sectors, 472 KB)
 - 0xB4000 - 0xB7FFF (  4 Sectors, 16 KB)
 - 0xD4000 - 0xD4FFF (  1 Sector, 4 KB)
 - 0xF4000 - 0xFFFFF ( 12 Sectors, 48 KB)
 - 0x10001000 - 0x10001FFF (  1 Sector, 4 KB)
 - Start of verifying flash
 - End of verifying flash
 - Start of restoring
 - End of restoring
 - Executing exit sequence ...
  - De-initialized successfully
 - Target erased, programmed and verified successfully - Completed after 22.704 sec
Do a chip erase instead of a sector erase and blank check for each sector. It’s significantly faster.
Awesome, thanks! Now its 8.5 seconds!
 - Connecting ...
 - Start of erasing chip
 - End of erasing chip
 - End of restoring
 - Target erased, programmed and verified successfully - Completed after 8.471 sec
@rickkas7 I programmed the Boron with a simple program included within the hex file. The device appears to be having an issue with the NCP. This happened on 2 new borons, but are v1.00 borons. Do you have any thoughts to what could be going on?
0000056357 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000004342 [app] INFO: serial connected
0000004342 [app] INFO: particle connecting
0000004345 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000004347 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000004348 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000004548 [mux] INFO: Starting GSM07.10 muxer
0000004548 [mux] INFO: GSM07.10 muxer thread started
0000004848 [mux] INFO: Stopping GSM07.10 muxer
0000004848 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000004849 [mux] INFO: Closing all muxed channels
0000004849 [mux] INFO: Muxed channel 1 already closed
0000004849 [mux] INFO: Muxed channel 2 already closed
0000004850 [mux] INFO: Muxed channel 3 already closed
0000004850 [mux] INFO: Muxed channel 4 already closed
0000005501 [mux] INFO: Sending CLD (multiplexer close down)
0000006401 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000006451 [mux] INFO: GSM07.10 muxer thread exiting
0000006451 [mux] INFO: GSM07.10 muxer stopped
0000006452 [mux] INFO: Starting GSM07.10 muxer
0000006452 [mux] INFO: GSM07.10 muxer thread started
0000006752 [mux] INFO: Stopping GSM07.10 muxer
0000006752 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000006752 [mux] INFO: Closing all muxed channels
0000006753 [mux] INFO: Muxed channel 1 already closed
0000006753 [mux] INFO: Muxed channel 2 already closed
0000006754 [mux] INFO: Muxed channel 3 already closed
0000006754 [mux] INFO: Muxed channel 4 already closed
0000007405 [mux] INFO: Sending CLD (multiplexer close down)
0000008305 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000008355 [mux] INFO: GSM07.10 muxer thread exiting
0000008355 [mux] INFO: GSM07.10 muxer stopped
0000015356 [ncp.client] ERROR: No response from NCP
0000067837 [ncp.client] INFO: Using internal SIM card
0000068917 [mux] INFO: Starting GSM07.10 muxer
0000068917 [mux] INFO: Openning mux channel 0
0000068918 [mux] INFO: GSM07.10 muxer thread started
0000068921 [mux] INFO: Openning mux channel 1
#include "Particle.h"
void startUpFunction();
STARTUP(startUpFunction());
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
SerialLogHandler logHandler;
int outOfMemory = -1;
void outOfMemoryHandler(system_event_t event, int param);
  Time.zone(-5);
  System.on(out_of_memory, outOfMemoryHandler);
  waitFor(Serial.isConnected, 5000);
  Log.info("serial connected");
  Particle.connect();
  Log.info("particle connecting");
void outOfMemoryHandler(system_event_t event, int param) {
    outOfMemory = param;
void startUpFunction() {
  System.enableFeature(FEATURE_RETAINED_MEMORY);
Try setting the log level higher to see what the actual error is:
The cellular NCP isn’t ever upgraded, so it’s probably not an issue with how you flashed it, because none of the upgrade methods will reprogram the cellular modem, which can’t be programmed by serial or SWD/JTAG.
Below is logging with LOG_LEVEL_TRACE enabled
0000002846 [app] INFO: serial connected
0000002847 [app] INFO: particle connecting
0000002850 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000002850 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000002852 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0000002852 [ncp.client] TRACE: Modem already on
0000002852 [ncp.client] TRACE: Setting UART voltage translator state 1
0000002853 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000002952 [ncp.client] TRACE: Setting UART voltage translator state 0
0000003052 [ncp.client] TRACE: Setting UART voltage translator state 1
0000003053 [ncp.client] TRACE: Muxer is not currently running
0000003054 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000003055 [mux] INFO: Starting GSM07.10 muxer
0000003055 [mux] INFO: GSM07.10 muxer thread started
0000003355 [mux] INFO: Stopping GSM07.10 muxer
0000003355 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000003356 [mux] INFO: Closing all muxed channels
0000003356 [mux] INFO: Muxed channel 1 already closed
0000003357 [mux] INFO: Muxed channel 2 already closed
0000003357 [mux] INFO: Muxed channel 3 already closed
0000003358 [mux] INFO: Muxed channel 4 already closed
0000004009 [mux] INFO: Sending CLD (multiplexer close down)
0000004912 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000004962 [mux] INFO: GSM07.10 muxer thread exiting
0000004963 [mux] INFO: GSM07.10 muxer stopped
0000004963 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000004964 [mux] INFO: Starting GSM07.10 muxer
0000004964 [mux] INFO: GSM07.10 muxer thread started
0000004968 [ncp.client] TRACE: Resumed muxed session
0000004968 [mux] INFO: Openning mux channel 1
0000005321 [mux] INFO: Closing mux channel 2
0000005674 [ncp.at] TRACE: > AT
0000005681 [ncp.at] TRACE: < OK
0000005682 [ncp.client] TRACE: NCP ready to accept AT commands
0000005683 [ncp.at] TRACE: > AT
0000005688 [ncp.at] TRACE: < OK
0000005689 [ncp.at] TRACE: > ATI9
0000005697 [ncp.at] TRACE: < L0.0.00.00.05.06,A.02.00
0000005698 [ncp.at] TRACE: < OK
0000005698 [ncp.client] TRACE: App firmware: 200
0000005698 [ncp.at] TRACE: > AT+UGPIOC?
0000005711 [ncp.at] TRACE: < +UGPIOC:
0000005711 [ncp.at] TRACE: < 16,255
0000005711 [ncp.at] TRACE: < 19,255
0000005712 [ncp.at] TRACE: < 23,0
0000005712 [ncp.at] TRACE: < 24,255
0000005713 [ncp.at] TRACE: < 25,255
0000005713 [ncp.at] TRACE: < 42,255
0000005713 [ncp.at] TRACE: < OK
0000005714 [ncp.at] TRACE: > AT+UGPIOR=23
0000005723 [ncp.at] TRACE: < +UGPIOR: 23,1
0000005723 [ncp.at] TRACE: < OK
0000005723 [ncp.client] INFO: Using internal SIM card
0000005724 [ncp.at] TRACE: > AT+CPIN?
0000005733 [ncp.at] TRACE: < +CPIN: READY
0000005733 [ncp.at] TRACE: < OK
0000005734 [ncp.at] TRACE: > AT+CCID
0000005744 [ncp.at] TRACE: < +CCID: 89014103271226450953
0000005744 [ncp.at] TRACE: < OK
0000005745 [ncp.at] TRACE: > AT+IFC=2,2
0000005752 [ncp.at] TRACE: < OK
0000005753 [ncp.at] TRACE: > AT
0000005758 [ncp.at] TRACE: < OK
0000005759 [ncp.at] TRACE: > AT+CCID
0000005769 [ncp.at] TRACE: < +CCID: 89014103271226450953
0000005769 [ncp.at] TRACE: < OK
0000005770 [ncp.at] TRACE: > AT+CIMI
0000005779 [ncp.at] TRACE: < 310410122645095
0000005779 [ncp.at] TRACE: < OK
0000005780 [ncp.at] TRACE: > AT+UMNOPROF?
0000005789 [ncp.at] TRACE: < +UMNOPROF: 2
0000005789 [ncp.at] TRACE: < OK
0000005790 [ncp.at] TRACE: > AT+COPS=3,2
0000005797 [ncp.at] TRACE: < OK
0000005798 [ncp.at] TRACE: > AT+CGEREP=1,0
0000005806 [ncp.at] TRACE: < OK
0000005807 [ncp.at] TRACE: > AT+URAT?
0000005815 [ncp.at] TRACE: < +URAT: 7
0000005815 [ncp.at] TRACE: < OK
0000005816 [ncp.at] TRACE: > AT+CPSMS?
0000005826 [ncp.at] TRACE: < +CPSMS:0,,,"01100000","00000000"
0000005827 [ncp.at] TRACE: < OK
0000005827 [ncp.at] TRACE: > AT+CEDRXS?
0000005836 [ncp.at] TRACE: < +CEDRXS:
0000005836 [ncp.at] TRACE: < OK
0000005836 [mux] INFO: Mux channel 1 already opened
0000005837 [ncp.at] TRACE: > AT
0000005843 [ncp.at] TRACE: < OK
0000005843 [ncp.client] TRACE: NCP state changed: 1
0000005843 [net.pppncp] TRACE: NCP event 1
0000005844 [net.ppp.client] TRACE: PPP thread event ADM_UP
0000005845 [net.ppp.client] TRACE: State NONE -> READY
0000005847 [ncp.at] TRACE: > AT+CFUN?
0000005854 [ncp.at] TRACE: < +CFUN: 1
0000005855 [ncp.at] TRACE: < OK
0000005855 [ncp.at] TRACE: > AT+CCID
0000005865 [ncp.at] TRACE: < +CCID: 89014103271226450953
0000005865 [ncp.at] TRACE: < OK
0000005866 [ncp.at] TRACE: > AT+CIMI
0000005874 [ncp.at] TRACE: < 310410122645095
0000005874 [ncp.at] TRACE: < OK
0000005875 [ncp.at] TRACE: > AT+CGDCONT?
0000005887 [ncp.at] TRACE: < +CGDCONT: 1,"IP","10569.mcs","0.0.0.0",0,0,0,0
0000005887 [ncp.at] TRACE: < OK
0000005888 [ncp.at] TRACE: > AT+CFUN?
0000005896 [ncp.at] TRACE: < +CFUN: 1
0000005897 [ncp.at] TRACE: < OK
0000005897 [ncp.at] TRACE: > AT+CEREG=2
0000005905 [ncp.at] TRACE: < OK
0000005905 [ncp.client] TRACE: NCP connection state changed: 1
0000005906 [net.pppncp] TRACE: NCP event 2
0000005906 [net.pppncp] TRACE: State changed event: 1
0000005906 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000005907 [ncp.at] TRACE: > AT+COPS?
0000005915 [ncp.at] TRACE: < +COPS: 0
0000005915 [ncp.at] TRACE: < OK
0000005916 [ncp.at] TRACE: > AT+CEREG?
0000005924 [ncp.at] TRACE: < +CEREG: 2,3
0000005924 [ncp.at] TRACE: < OK
0000021024 [ncp.at] TRACE: > AT+CEREG?
0000021033 [ncp.at] TRACE: < +CEREG: 2,3
0000021033 [ncp.at] TRACE: < OK
0000021034 [ncp.at] TRACE: > AT+UCGED=5
0000021041 [ncp.at] TRACE: < OK
0000021042 [ncp.at] TRACE: > AT+UCGED?
0000021051 [ncp.at] TRACE: < +RSRP:
0000021051 [ncp.at] TRACE: < +RSRQ:
0000021051 [ncp.at] TRACE: < OK
0000021151 [ncp.client] TRACE: Sticky EPS denied state for 15 s, RF reset
0000021153 [ncp.at] TRACE: > AT+CFUN=0
0000021209 [ncp.at] TRACE: < OK
0000021210 [ncp.at] TRACE: > AT+CFUN=1,0
0000021218 [ncp.at] TRACE: < OK
0000036118 [ncp.at] TRACE: > AT+CEREG?
0000036126 [ncp.at] TRACE: < +CEREG: 2,3
0000036127 [ncp.at] TRACE: < OK
0000036128 [ncp.at] TRACE: > AT+UCGED=5
0000036135 [ncp.at] TRACE: < OK
0000036135 [ncp.at] TRACE: > AT+UCGED?
0000036144 [ncp.at] TRACE: < +CME ERROR: unknown
0000051145 [ncp.at] TRACE: > AT+CEREG?
0000051153 [ncp.at] TRACE: < +CEREG: 2,3
0000051154 [ncp.at] TRACE: < OK
0000051155 [ncp.at] TRACE: > AT+UCGED=5
0000051162 [ncp.at] TRACE: < OK
0000051163 [ncp.at] TRACE: > AT+UCGED?
0000051171 [ncp.at] TRACE: < +CME ERROR: unknown
0000065971 [ncp.at] TRACE: > AT+CIMI
0000065980 [ncp.at] TRACE: < 310410122645095
0000065980 [ncp.at] TRACE: < OK
0000066179 [ncp.client] TRACE: Sticky EPS denied state for 30 s, RF reset
0000066180 [ncp.at] TRACE: > AT+CFUN=0
0000066284 [ncp.at] TRACE: < OK
0000066284 [ncp.at] TRACE: > AT+CFUN=1,0
0000066292 [ncp.at] TRACE: < OK
0000066293 [ncp.at] TRACE: > AT+CEREG?
0000066301 [ncp.at] TRACE: < +CEREG: 2,3
0000066301 [ncp.at] TRACE: < OK
0000066302 [ncp.at] TRACE: > AT+UCGED=5
0000066310 [ncp.at] TRACE: < OK
0000066310 [ncp.at] TRACE: > AT+UCGED?
0000066320 [ncp.at] TRACE: < +CME ERROR: no network service
0000081321 [ncp.at] TRACE: > AT+CEREG?
0000081329 [ncp.at] TRACE: < +CEREG: 2,3
0000081330 [ncp.at] TRACE: < OK
0000081331 [ncp.at] TRACE: > AT+UCGED=5
0000081337 [ncp.at] TRACE: < OK
0000081338 [ncp.at] TRACE: > AT+UCGED?
0000081346 [ncp.at] TRACE: < +CME ERROR: unknown
0000096447 [ncp.at] TRACE: > AT+CEREG?
0000096456 [ncp.at] TRACE: < +CEREG: 2,3
0000096456 [ncp.at] TRACE: < OK
0000096456 [ncp.at] TRACE: > AT+UCGED=5
0000096463 [ncp.at] TRACE: < OK
0000096464 [ncp.at] TRACE: > AT+UCGED?
0000096472 [ncp.at] TRACE: < +CME ERROR: unknown
0000111372 [ncp.client] TRACE: Sticky EPS denied state for 45 s, RF reset
0000111374 [ncp.at] TRACE: > AT+CFUN=0
0000111427 [ncp.at] TRACE: < OK
0000111427 [ncp.at] TRACE: > AT+CFUN=1,0
0000111435 [ncp.at] TRACE: < OK
0000111536 [ncp.at] TRACE: > AT+CEREG?
0000111544 [ncp.at] TRACE: < +CEREG: 2,3
0000111545 [ncp.at] TRACE: < OK
0000111545 [ncp.at] TRACE: > AT+UCGED=5
0000111553 [ncp.at] TRACE: < OK
0000111553 [ncp.at] TRACE: > AT+UCGED?
0000111563 [ncp.at] TRACE: < +CME ERROR: no network service
0000126064 [ncp.at] TRACE: > AT+CIMI
0000126073 [ncp.at] TRACE: < 310410122645095
0000126073 [ncp.at] TRACE: < OK
0000126574 [ncp.at] TRACE: > AT+CEREG?
0000126583 [ncp.at] TRACE: < +CEREG: 2,3
0000126583 [ncp.at] TRACE: < OK
0000126584 [ncp.at] TRACE: > AT+UCGED=5
0000126591 [ncp.at] TRACE: < OK
0000126592 [ncp.at] TRACE: > AT+UCGED?
0000126600 [ncp.at] TRACE: < +CME ERROR: unknown
0000141701 [ncp.at] TRACE: > AT+CEREG?
0000141709 [ncp.at] TRACE: < +CEREG: 2,3
0000141710 [ncp.at] TRACE: < OK
0000141710 [ncp.at] TRACE: > AT+UCGED=5
0000141718 [ncp.at] TRACE: < OK
0000141718 [ncp.at] TRACE: > AT+UCGED?
0000141727 [ncp.at] TRACE: < +CME ERROR: unknown
0000156827 [ncp.at] TRACE: > AT+CEREG?
0000156838 [ncp.at] TRACE: < +CEREG: 2,3
0000156838 [ncp.at] TRACE: < OK
0000156839 [ncp.at] TRACE: > AT+UCGED=5
0000156849 [ncp.at] TRACE: < OK
0000156850 [ncp.at] TRACE: > AT+UCGED?
0000156874 [ncp.at] TRACE: < +RSRP: 438,5035,"-108.80",370,5035,"-108.70",329,5035,"-109.40",435,5035,"-109.40",
0000156875 [ncp.at] TRACE: < +RSRQ: 438,5035,"-18.00",370,5035,"-17.20",329,5035,"-17.80",435,5035,"-17.90",
0000156876 [ncp.at] TRACE: < OK
0000171575 [ncp.client] TRACE: Sticky EPS denied state for 60 s, RF reset
0000171576 [ncp.at] TRACE: > AT+CFUN=0
0000171631 [ncp.at] TRACE: < OK
0000171632 [ncp.at] TRACE: > AT+CFUN=1,0
0000171639 [ncp.at] TRACE: < OK
0000171940 [ncp.at] TRACE: > AT+CEREG?
0000171949 [ncp.at] TRACE: < +CEREG: 2,3
0000171949 [ncp.at] TRACE: < OK
0000171950 [ncp.at] TRACE: > AT+UCGED=5
0000171957 [ncp.at] TRACE: < OK
0000171958 [ncp.at] TRACE: > AT+UCGED?
0000171968 [ncp.at] TRACE: < +CME ERROR: no network service
0000186168 [ncp.at] TRACE: > AT+CIMI
0000186176 [ncp.at] TRACE: < 310410122645095
0000186177 [ncp.at] TRACE: < OK
0000186977 [ncp.at] TRACE: > AT+CEREG?
0000186985 [ncp.at] TRACE: < +CEREG: 2,3
0000186986 [ncp.at] TRACE: < OK
0000186986 [ncp.at] TRACE: > AT+UCGED=5
0000186994 [ncp.at] TRACE: < OK
0000186995 [ncp.at] TRACE: > AT+UCGED?
0000187003 [ncp.at] TRACE: < +CME ERROR: unknown
0000202104 [ncp.at] TRACE: > AT+CEREG?
0000202113 [ncp.at] TRACE: < +CEREG: 2,3
0000202113 [ncp.at] TRACE: < OK
0000202114 [ncp.at] TRACE: > AT+UCGED=5
0000202121 [ncp.at] TRACE: < OK
0000202122 [ncp.at] TRACE: > AT+UCGED?
0000202131 [ncp.at] TRACE: < +RSRP:
0000202131 [ncp.at] TRACE: < +RSRQ:
0000202131 [ncp.at] TRACE: < OK
0000217232 [ncp.at] TRACE: > AT+CEREG?
0000217241 [ncp.at] TRACE: < +CEREG: 2,3
0000217241 [ncp.at] TRACE: < OK
0000217242 [ncp.at] TRACE: > AT+UCGED=5
0000217249 [ncp.at] TRACE: < OK
0000217250 [ncp.at] TRACE: > AT+UCGED?
0000217262 [ncp.at] TRACE: < +RSRP: 212,5110,"-102.20",
0000217263 [ncp.at] TRACE: < +RSRQ: 212,5110,"-13.60",
0000217263 [ncp.at] TRACE: < OK
0000232364 [ncp.at] TRACE: > AT+CEREG?
0000232373 [ncp.at] TRACE: < +CEREG: 2,3
0000232373 [ncp.at] TRACE: < OK
0000232374 [ncp.at] TRACE: > AT+UCGED=5
0000232381 [ncp.at] TRACE: < OK
0000232382 [ncp.at] TRACE: > AT+UCGED?
0000232390 [ncp.at] TRACE: < +CME ERROR: unknown
0000246191 [ncp.at] TRACE: > AT+CIMI
0000246199 [ncp.at] TRACE: < 310410122645095
0000246200 [ncp.at] TRACE: < OK
0000246999 [ncp.client] TRACE: Sticky EPS denied state for 75 s, RF reset
0000247000 [ncp.at] TRACE: > AT+CFUN=0
0000247047 [ncp.at] TRACE: < OK
0000247048 [ncp.at] TRACE: > AT+CFUN=1,0
0000247055 [ncp.at] TRACE: < OK
0000247456 [ncp.at] TRACE: > AT+CEREG?
0000247465 [ncp.at] TRACE: < +CEREG: 2,3
0000247465 [ncp.at] TRACE: < OK
0000247466 [ncp.at] TRACE: > AT+UCGED=5
0000247473 [ncp.at] TRACE: < OK
0000247474 [ncp.at] TRACE: > AT+UCGED?
0000247483 [ncp.at] TRACE: < +CME ERROR: no network service
0000262584 [ncp.at] TRACE: > AT+CEREG?
0000262593 [ncp.at] TRACE: < +CEREG: 2,3
0000262593 [ncp.at] TRACE: < OK
0000262594 [ncp.at] TRACE: > AT+UCGED=5
0000262601 [ncp.at] TRACE: < OK
0000262602 [ncp.at] TRACE: > AT+UCGED?
0000262611 [ncp.at] TRACE: < +RSRP:
0000262611 [ncp.at] TRACE: < +RSRQ:
0000262612 [ncp.at] TRACE: < OK
0000277712 [ncp.at] TRACE: > AT+CEREG?
0000277720 [ncp.at] TRACE: < +CEREG: 2,3
0000277721 [ncp.at] TRACE: < OK
0000277722 [ncp.at] TRACE: > AT+UCGED=5
0000277729 [ncp.at] TRACE: < OK
0000277730 [ncp.at] TRACE: > AT+UCGED?
0000277738 [ncp.at] TRACE: < +CME ERROR: unknown
0000292839 [ncp.at] TRACE: > AT+CEREG?
0000292848 [ncp.at] TRACE: < +CEREG: 2,3
0000292848 [ncp.at] TRACE: < OK
0000292849 [ncp.at] TRACE: > AT+UCGED=5
0000292856 [ncp.at] TRACE: < OK
0000292857 [ncp.at] TRACE: > AT+UCGED?
0000292866 [ncp.at] TRACE: < +RSRP:
0000292866 [ncp.at] TRACE: < +RSRQ:
0000292866 [ncp.at] TRACE: < OK
0000306267 [ncp.at] TRACE: > AT+CIMI
0000306278 [ncp.at] TRACE: < 310410122645095
0000306278 [ncp.at] TRACE: < OK
0000307878 [ncp.at] TRACE: > AT+CEREG?
0000307889 [ncp.at] TRACE: < +CEREG: 2,3
0000307889 [ncp.at] TRACE: < OK
0000307890 [ncp.at] TRACE: > AT+UCGED=5
0000307900 [ncp.at] TRACE: < OK
0000307900 [ncp.at] TRACE: > AT+UCGED?
0000307915 [ncp.at] TRACE: < +RSRP: 212,5110,"-101.60",
0000307916 [ncp.at] TRACE: < +RSRQ: 212,5110,"-12.60",
0000307916 [ncp.at] TRACE: < OK
0000323017 [ncp.at] TRACE: > AT+CEREG?
0000323028 [ncp.at] TRACE: < +CEREG: 2,3
0000323028 [ncp.at] TRACE: < OK
0000323029 [ncp.at] TRACE: > AT+UCGED=5
0000323039 [ncp.at] TRACE: < OK
0000323039 [ncp.at] TRACE: > AT+UCGED?
0000323054 [ncp.at] TRACE: < +RSRP: 212,5110,"-101.60",
0000323055 [ncp.at] TRACE: < +RSRQ: 212,5110,"-13.80",
0000323055 [ncp.at] TRACE: < OK
0000337555 [ncp.client] TRACE: Sticky EPS denied state for 90 s, RF reset
0000337556 [ncp.at] TRACE: > AT+CFUN=0
0000337608 [ncp.at] TRACE: < OK
0000337609 [ncp.at] TRACE: > AT+CFUN=1,0
0000337617 [ncp.at] TRACE: < OK
0000338117 [ncp.at] TRACE: > AT+CEREG?
0000338126 [ncp.at] TRACE: < +CEREG: 2,3
0000338126 [ncp.at] TRACE: < OK
0000338127 [ncp.at] TRACE: > AT+UCGED=5
0000338134 [ncp.at] TRACE: < OK
0000338135 [ncp.at] TRACE: > AT+UCGED?
0000338147 [ncp.at] TRACE: < +RSRP: 212,5110,"-102.40",
0000338148 [ncp.at] TRACE: < +RSRQ: 212,5110,"-14.10",
0000338148 [ncp.at] TRACE: < OK
0000353248 [ncp.at] TRACE: > AT+CEREG?
0000353256 [ncp.at] TRACE: < +CEREG: 2,3
0000353257 [ncp.at] TRACE: < OK
0000353257 [ncp.at] TRACE: > AT+UCGED=5
0000353265 [ncp.at] TRACE: < OK
0000353265 [ncp.at] TRACE: > AT+UCGED?
0000353274 [ncp.at] TRACE: < +CME ERROR: unknown
0000366374 [ncp.at] TRACE: > AT+CIMI
0000366382 [ncp.at] TRACE: < 310410122645095
0000366383 [ncp.at] TRACE: < OK
0000368283 [ncp.at] TRACE: > AT+CEREG?
0000368292 [ncp.at] TRACE: < +CEREG: 2,3
0000368292 [ncp.at] TRACE: < OK
0000368293 [ncp.at] TRACE: > AT+UCGED=5
0000368300 [ncp.at] TRACE: < OK
0000368301 [ncp.at] TRACE: > AT+UCGED?
0000368309 [ncp.at] TRACE: < +CME ERROR: unknown
0000383310 [ncp.at] TRACE: > AT+CEREG?
0000383319 [ncp.at] TRACE: < +CEREG: 2,3
0000383319 [ncp.at] TRACE: < OK
0000383320 [ncp.at] TRACE: > AT+UCGED=5
0000383328 [ncp.at] TRACE: < OK
0000383328 [ncp.at] TRACE: > AT+UCGED?
0000383337 [ncp.at] TRACE: < +RSRP:
0000383338 [ncp.at] TRACE: < +RSRQ:
0000383338 [ncp.at] TRACE: < OK
0000398438 [ncp.at] TRACE: > AT+CEREG?
0000398449 [ncp.at] TRACE: < +CEREG: 2,3
0000398449 [ncp.at] TRACE: < OK
0000398450 [ncp.at] TRACE: > AT+UCGED=5
0000398460 [ncp.at] TRACE: < OK
0000398460 [ncp.at] TRACE: > AT+UCGED?
0000398475 [ncp.at] TRACE: < +RSRP: 212,5110,"-102.50",
0000398476 [ncp.at] TRACE: < +RSRQ: 212,5110,"-16.50",
0000398476 [ncp.at] TRACE: < OK
0000413576 [ncp.at] TRACE: > AT+CEREG?
0000413587 [ncp.at] TRACE: < +CEREG: 2,3
0000413587 [ncp.at] TRACE: < OK
0000413588 [ncp.at] TRACE: > AT+UCGED=5
0000413598 [ncp.at] TRACE: < OK
0000413599 [ncp.at] TRACE: > AT+UCGED?
0000413613 [ncp.at] TRACE: < +RSRP: 212,5110,"-101.70",
0000413614 [ncp.at] TRACE: < +RSRQ: 212,5110,"-11.80",
0000413614 [ncp.at] TRACE: < OK
0000426414 [ncp.at] TRACE: > AT+CIMI
0000426425 [ncp.at] TRACE: < 310410122645095
0000426425 [ncp.at] TRACE: < OK
0000428625 [ncp.at] TRACE: > AT+CEREG?
0000428636 [ncp.at] TRACE: < +CEREG: 2,3
0000428636 [ncp.at] TRACE: < OK
0000428637 [ncp.at] TRACE: > AT+UCGED=5
0000428647 [ncp.at] TRACE: < OK
0000428648 [ncp.at] TRACE: > AT+UCGED?
0000428685 [ncp.at] TRACE: < +RSRP: 212,5110,"-101.80",083,5110,"-109.20",353,5110,"-110.00",412,5110,"-106.40",133,5110,"-109.60",011,5110,"-110.20",126,511
0000428686 [ncp.at] TRACE: < +RSRQ: 212,5110,"-14.20",083,5110,"-20.00",353,5110,"-20.00",412,5110,"-18.80",133,5110,"-20.00",011,5110,"-20.00",126,5110,"-20
0000428687 [ncp.at] TRACE: < OK
0000443187 [ncp.client] TRACE: Sticky EPS denied state for 105 s, RF reset
0000443188 [ncp.at] TRACE: > AT+CFUN=0
0000443263 [ncp.at] TRACE: < OK
0000443264 [ncp.at] TRACE: > AT+CFUN=1,0
0000443271 [ncp.at] TRACE: < OK
0000443772 [ncp.at] TRACE: > AT+CEREG?
0000443782 [ncp.at] TRACE: < +CEREG: 2,3
0000443782 [ncp.at] TRACE: < OK
0000443783 [ncp.at] TRACE: > AT+UCGED=5
0000443792 [ncp.at] TRACE: < OK
0000443792 [ncp.at] TRACE: > AT+UCGED?
0000443812 [ncp.at] TRACE: < +RSRP: 212,5110,"-102.50",
0000443812 [ncp.at] TRACE: < +RSRQ: 212,5110,"-16.00",
0000443813 [ncp.at] TRACE: < OK
0000458913 [ncp.at] TRACE: > AT+CEREG?
0000458921 [ncp.at] TRACE: < +CEREG: 2,3
0000458922 [ncp.at] TRACE: < OK
0000458923 [ncp.at] TRACE: > AT+UCGED=5
0000458929 [ncp.at] TRACE: < OK
0000458930 [ncp.at] TRACE: > AT+UCGED?
0000458938 [ncp.at] TRACE: < +CME ERROR: unknown
0000474039 [ncp.at] TRACE: > AT+CEREG?
0000474048 [ncp.at] TRACE: < +CEREG: 2,3
0000474048 [ncp.at] TRACE: < OK
0000474049 [ncp.at] TRACE: > AT+UCGED=5
0000474056 [ncp.at] TRACE: < OK
0000474057 [ncp.at] TRACE: > AT+UCGED?
0000474065 [ncp.at] TRACE: < +CME ERROR: unknown
0000486466 [ncp.at] TRACE: > AT+CIMI
0000486475 [ncp.at] TRACE: < 310410122645095
0000486475 [ncp.at] TRACE: < OK
0000489075 [ncp.at] TRACE: > AT+CEREG?
0000489084 [ncp.at] TRACE: < +CEREG: 2,3
0000489084 [ncp.at] TRACE: < OK
0000489085 [ncp.at] TRACE: > AT+UCGED=5
0000489092 [ncp.at] TRACE: < OK
0000489093 [ncp.at] TRACE: > AT+UCGED?
0000489100 [ncp.at] TRACE: < +CME ERROR: unknown
0000504201 [ncp.at] TRACE: > AT+CEREG?
0000504212 [ncp.at] TRACE: < +CEREG: 2,3
0000504212 [ncp.at] TRACE: < OK
0000504213 [ncp.at] TRACE: > AT+UCGED=5
0000504222 [ncp.at] TRACE: < OK
0000504223 [ncp.at] TRACE: > AT+UCGED?
0000504256 [ncp.at] TRACE: < +RSRP: 212,5110,"-101.60",412,5110,"-105.10",150,5110,"-109.60",045,5110,"-107.40",005,5110,"-110.70",290,5110,"-108.90",490,511
0000504258 [ncp.at] TRACE: < +RSRQ: 212,5110,"-15.60",412,5110,"-17.00",150,5110,"-20.00",045,5110,"-20.00",005,5110,"-20.00",290,5110,"-20.00",490,5110,"-20
0000504258 [ncp.at] TRACE: < OK
0000519359 [ncp.at] TRACE: > AT+CEREG?
0000519370 [ncp.at] TRACE: < +CEREG: 2,3
0000519370 [ncp.at] TRACE: < OK
0000519371 [ncp.at] TRACE: > AT+UCGED=5
0000519381 [ncp.at] TRACE: < OK
0000519382 [ncp.at] TRACE: > AT+UCGED?
0000519400 [ncp.at] TRACE: < +RSRP: 212,5110,"-102.20",412,5110,"-108.80",
0000519400 [ncp.at] TRACE: < +RSRQ: 212,5110,"-12.70",412,5110,"-19.50",
0000519400 [ncp.at] TRACE: < OK
0000534501 [ncp.at] TRACE: > AT+CEREG?
0000534510 [ncp.at] TRACE: < +CEREG: 2,3
0000534510 [ncp.at] TRACE: < OK
0000534511 [ncp.at] TRACE: > AT+UCGED=5
0000534518 [ncp.at] TRACE: < OK
0000534519 [ncp.at] TRACE: > AT+UCGED?
0000534528 [ncp.at] TRACE: < +CME ERROR: unknown
0000546528 [ncp.at] TRACE: > AT+CIMI
0000546537 [ncp.at] TRACE: < 310410122645095
0000546537 [ncp.at] TRACE: < OK
0000549538 [ncp.at] TRACE: > AT+CEREG?
0000549549 [ncp.at] TRACE: < +CEREG: 2,3
0000549549 [ncp.at] TRACE: < OK
0000549550 [ncp.at] TRACE: > AT+UCGED=5
0000549560 [ncp.at] TRACE: < OK
0000549561 [ncp.at] TRACE: > AT+UCGED?
0000549576 [ncp.at] TRACE: < +RSRP: 212,5110,"-102.10",
0000549576 [ncp.at] TRACE: < +RSRQ: 212,5110,"-13.80",
0000549576 [ncp.at] TRACE: < OK
0000563876 [ncp.client] TRACE: Sticky EPS denied state for 120 s, RF reset
0000563877 [ncp.at] TRACE: > AT+CFUN=0
0000563952 [ncp.at] TRACE: < OK
0000563953 [ncp.at] TRACE: > AT+CFUN=1,0
0000563961 [ncp.at] TRACE: < OK
0000564661 [ncp.at] TRACE: > AT+CEREG?
0000564670 [ncp.at] TRACE: < +CEREG: 2,3
0000564670 [ncp.at] TRACE: < OK
0000564671 [ncp.at] TRACE: > AT+UCGED=5
0000564678 [ncp.at] TRACE: < OK
0000564679 [ncp.at] TRACE: > AT+UCGED?
0000564691 [ncp.at] TRACE: < +RSRP: 212,5110,"-102.00",
0000564692 [ncp.at] TRACE: < +RSRQ: 212,5110,"-13.70",
0000564692 [ncp.at] TRACE: < OK
0000579792 [ncp.at] TRACE: > AT+CEREG?
0000579800 [ncp.at] TRACE: < +CEREG: 2,3
0000579801 [ncp.at] TRACE: < OK
0000579801 [ncp.at] TRACE: > AT+UCGED=5
0000579809 [ncp.at] TRACE: < OK
0000579809 [ncp.at] TRACE: > AT+UCGED?
0000579818 [ncp.at] TRACE: < +CME ERROR: unknown
0000594919 [ncp.at] TRACE: > AT+CEREG?
0000594928 [ncp.at] TRACE: < +CEREG: 2,3
0000594928 [ncp.at] TRACE: < OK
0000594929 [ncp.at] TRACE: > AT+UCGED=5
0000594936 [ncp.at] TRACE: < OK
0000594937 [ncp.at] TRACE: > AT+UCGED?
0000594949 [ncp.at] TRACE: < +RSRP: 329,5035,"-111.40",
0000594950 [ncp.at] TRACE: < +RSRQ: 329,5035,"-20.00",
0000594951 [ncp.at] TRACE: < OK
0000606551 [ncp.at] TRACE: > AT+CIMI
0000606559 [ncp.at] TRACE: < 310410122645095
0000606560 [ncp.at] TRACE: < OK
0000609960 [ncp.at] TRACE: > AT+CEREG?
0000609968 [ncp.at] TRACE: < +CEREG: 2,3
0000609969 [ncp.at] TRACE: < OK
0000609970 [ncp.at] TRACE: > AT+UCGED=5
0000609977 [ncp.at] TRACE: < OK
0000609978 [ncp.at] TRACE: > AT+UCGED?
0000609986 [ncp.at] TRACE: < +CME ERROR: unknown
0000609987 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0000609988 [ncp.client] TRACE: NCP connection state changed: 0
0000609988 [net.pppncp] TRACE: NCP event 2
0000609988 [net.pppncp] TRACE: State changed event: 0
0000609989 [ncp.client] TRACE: NCP state changed: 0
0000609989 [net.pppncp] TRACE: NCP event 1
0000609989 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000609990 [mux] INFO: Stopping GSM07.10 muxer
0000609990 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000609991 [mux] INFO: Closing all muxed channels
0000609991 [mux] INFO: Closing mux channel 1
0000609991 [mux] INFO: Muxed channel 2 already closed
0000609992 [mux] INFO: Muxed channel 3 already closed
0000609992 [mux] INFO: Muxed channel 4 already closed
0000609995 [mux] INFO: Sending CLD (multiplexer close down)
0000609998 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000609999 [mux] INFO: GSM07.10 muxer thread exiting
0000609999 [mux] INFO: GSM07.10 muxer stopped
0000610000 [net.pppncp] TRACE: NCP event 3
0000610000 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000610000 [system.nm] TRACE: Interface 4 power state changed: 3
0000610001 [ncp.client] TRACE: Powering modem off using hardware control
0000610002 [ncp.client] TRACE: Setting UART voltage translator state 0
0000610002 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
0000641682 [net.pppncp] TRACE: NCP event 3
0000641683 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000641683 [system.nm] TRACE: Interface 4 power state changed: 1
0000641683 [ncp.client] TRACE: Modem powered off
0000641783 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0000641784 [net.pppncp] TRACE: NCP event 3
0000641784 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000641784 [system.nm] TRACE: Interface 4 power state changed: 4
0000641934 [net.pppncp] TRACE: NCP event 3
0000641935 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000641935 [system.nm] TRACE: Interface 4 power state changed: 2
0000641935 [ncp.client] TRACE: Modem powered on
0000641936 [ncp.client] TRACE: Setting UART voltage translator state 1
0000642035 [ncp.client] TRACE: Setting UART voltage translator state 0
0000642135 [ncp.client] TRACE: Setting UART voltage translator state 1
0000643137 [ncp.at] TRACE: > AT
0000644138 [ncp.at] TRACE: > AT
0000645139 [ncp.at] TRACE: > AT
0000646140 [ncp.at] TRACE: > AT
0000647141 [ncp.at] TRACE: > AT
0000648142 [ncp.at] TRACE: > AT
0000649143 [ncp.at] TRACE: > AT
0000650144 [ncp.at] TRACE: > AT
0000651145 [ncp.at] TRACE: > AT
0000652146 [ncp.at] TRACE: > AT
0000653148 [ncp.at] TRACE: > AT
0000653151 [ncp.at] TRACE: < OK
0000653152 [ncp.client] TRACE: NCP ready to accept AT commands
0000653152 [ncp.at] TRACE: > AT
0000653155 [ncp.at] TRACE: < OK
0000653155 [ncp.at] TRACE: > ATI9
0000653160 [ncp.at] TRACE: < L0.0.00.00.05.06,A.02.00
0000653161 [ncp.at] TRACE: < OK
0000653161 [ncp.client] TRACE: App firmware: 200
0000653162 [ncp.at] TRACE: > AT+UGPIOC?
0000653167 [ncp.at] TRACE: < +UGPIOC:
0000653167 [ncp.at] TRACE: < 16,255
0000653168 [ncp.at] TRACE: < 19,255
0000653169 [ncp.at] TRACE: < 23,0
0000653169 [ncp.at] TRACE: < 24,255
0000653170 [ncp.at] TRACE: < 25,255
0000653171 [ncp.at] TRACE: < 42,255
0000653171 [ncp.at] TRACE: < OK
0000653172 [ncp.at] TRACE: > AT+UGPIOR=23
0000653177 [ncp.at] TRACE: < +UGPIOR: 23,1
0000653178 [ncp.at] TRACE: < OK
0000653178 [ncp.client] INFO: Using internal SIM card
0000653179 [ncp.at] TRACE: > AT+CPIN?
0000653184 [ncp.at] TRACE: < +CPIN: READY
0000653184 [ncp.at] TRACE: < OK
0000653185 [ncp.at] TRACE: > AT+CCID
0000653191 [ncp.at] TRACE: < +CCID: 89014103271226450953
0000653192 [ncp.at] TRACE: < OK
0000653192 [ncp.at] TRACE: > AT+IFC=2,2
0000653196 [ncp.at] TRACE: < OK
0000653196 [ncp.at] TRACE: > AT
0000653200 [ncp.at] TRACE: < OK
0000654200 [ncp.at] TRACE: > AT
0000654204 [ncp.at] TRACE: < OK
0000654204 [ncp.at] TRACE: > AT+CCID
0000654210 [ncp.at] TRACE: < +CCID: 89014103271226450953
0000654211 [ncp.at] TRACE: < OK
0000654211 [ncp.at] TRACE: > AT+CIMI
0000654217 [ncp.at] TRACE: < 310410122645095
0000654217 [ncp.at] TRACE: < OK
0000654218 [ncp.at] TRACE: > AT+UMNOPROF?
0000654224 [ncp.at] TRACE: < +UMNOPROF: 2
0000654224 [ncp.at] TRACE: < OK
0000654225 [ncp.at] TRACE: > AT+COPS=3,2
0000654229 [ncp.at] TRACE: < OK
0000654230 [ncp.at] TRACE: > AT+CGEREP=1,0
0000654235 [ncp.at] TRACE: < OK
0000654235 [ncp.at] TRACE: > AT+URAT?
0000654240 [ncp.at] TRACE: < +URAT: 7
0000654240 [ncp.at] TRACE: < OK
0000654240 [ncp.at] TRACE: > AT+CPSMS?
0000654248 [ncp.at] TRACE: < +CPSMS:0,,,"01100000","00000000"
0000654248 [ncp.at] TRACE: < OK
0000654248 [ncp.at] TRACE: > AT+CEDRXS?
0000654253 [ncp.at] TRACE: < +CEDRXS:
0000654254 [ncp.at] TRACE: < OK
0000654254 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000654261 [ncp.at] TRACE: < OK
0000654262 [mux] INFO: Starting GSM07.10 muxer
0000654262 [mux] INFO: Openning mux channel 0
0000654262 [mux] INFO: GSM07.10 muxer thread started
0000654265 [mux] INFO: Openning mux channel 1
0000654270 [ncp.at] TRACE: > AT
0000654279 [ncp.at] TRACE: < OK
0000654279 [ncp.client] TRACE: NCP state changed: 1
0000654279 [net.pppncp] TRACE: NCP event 1
0000654280 [net.ppp.client] TRACE: PPP thread event ADM_UP
0000654282 [ncp.at] TRACE: > AT+CFUN?
0000654290 [ncp.at] TRACE: < +CFUN: 1
0000654291 [ncp.at] TRACE: < OK
0000654291 [ncp.at] TRACE: > AT+CCID
0000654301 [ncp.at] TRACE: < +CCID: 89014103271226450953
0000654301 [ncp.at] TRACE: < OK
0000654302 [ncp.at] TRACE: > AT+CIMI
0000654311 [ncp.at] TRACE: < 310410122645095
0000654311 [ncp.at] TRACE: < OK
0000654312 [ncp.at] TRACE: > AT+CGDCONT?
0000654324 [ncp.at] TRACE: < +CGDCONT: 1,"IP","10569.mcs","0.0.0.0",0,0,0,0
0000654325 [ncp.at] TRACE: < OK
0000654325 [ncp.at] TRACE: > AT+CFUN?
0000654333 [ncp.at] TRACE: < +CFUN: 1
0000654334 [ncp.at] TRACE: < OK
0000654335 [ncp.at] TRACE: > AT+CEREG=2
0000654342 [ncp.at] TRACE: < OK
0000654343 [ncp.client] TRACE: NCP connection state changed: 1
0000654343 [net.pppncp] TRACE: NCP event 2
0000654343 [net.pppncp] TRACE: State changed event: 1
0000654343 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000654345 [ncp.at] TRACE: > AT+COPS?
0000654353 [ncp.at] TRACE: < +COPS: 0
0000654353 [ncp.at] TRACE: < OK
0000654354 [ncp.at] TRACE: > AT+CEREG?
0000654362 [ncp.at] TRACE: < +CEREG: 2,3
0000654363 [ncp.at] TRACE: < OK
0000669463 [ncp.at] TRACE: > AT+CEREG?
0000669472 [ncp.at] TRACE: < +CEREG: 2,3
0000669472 [ncp.at] TRACE: < OK
0000669473 [ncp.at] TRACE: > AT+UCGED=5
0000669480 [ncp.at] TRACE: < OK
0000669481 [ncp.at] TRACE: > AT+UCGED?
0000669493 [ncp.at] TRACE: < +RSRP: 212,5110,"-103.50",
0000669494 [ncp.at] TRACE: < +RSRQ: 212,5110,"-14.80",
0000669494 [ncp.at] TRACE: < OK
0000669593 [ncp.client] TRACE: Sticky EPS denied state for 15 s, RF reset
0000669594 [ncp.at] TRACE: > AT+CFUN=0
0000669757 [ncp.at] TRACE: < OK
0000669758 [ncp.at] TRACE: > AT+CFUN=1,0
0000669765 [ncp.at] TRACE: < OK
0000684566 [ncp.at] TRACE: > AT+CEREG?
0000684575 [ncp.at] TRACE: < +CEREG: 2,3
0000684576 [ncp.at] TRACE: < OK
0000684576 [ncp.at] TRACE: > AT+UCGED=5
0000684584 [ncp.at] TRACE: < OK
0000684584 [ncp.at] TRACE: > AT+UCGED?
0000684593 [ncp.at] TRACE: < +CME ERROR: unknown
0000699693 [ncp.at] TRACE: > AT+CEREG?
0000699702 [ncp.at] TRACE: < +CEREG: 2,3
0000699702 [ncp.at] TRACE: < OK
0000699703 [ncp.at] TRACE: > AT+UCGED=5
0000699710 [ncp.at] TRACE: < OK
0000699711 [ncp.at] TRACE: > AT+UCGED?
0000699720 [ncp.at] TRACE: < +RSRP:
0000699720 [ncp.at] TRACE: < +RSRQ:
0000699721 [ncp.at] TRACE: < OK
0000714421 [ncp.at] TRACE: > AT+CIMI
0000714430 [ncp.at] TRACE: < 310410122645095
0000714430 [ncp.at] TRACE: < OK
0000714630 [ncp.client] TRACE: Sticky EPS denied state for 30 s, RF reset
0000714631 [ncp.at] TRACE: > AT+CFUN=0
0000714686 [ncp.at] TRACE: < OK
0000714687 [ncp.at] TRACE: > AT+CFUN=1,0
0000714695 [ncp.at] TRACE: < OK
0000714795 [ncp.at] TRACE: > AT+CEREG?
0000714803 [ncp.at] TRACE: < +CEREG: 2,3
0000714804 [ncp.at] TRACE: < OK
0000714805 [ncp.at] TRACE: > AT+UCGED=5
0000714812 [ncp.at] TRACE: < OK
0000714813 [ncp.at] TRACE: > AT+UCGED?
0000714822 [ncp.at] TRACE: < +CME ERROR: no network service
0000729923 [ncp.at] TRACE: > AT+CEREG?
0000729931 [ncp.at] TRACE: < +CEREG: 2,3
0000729932 [ncp.at] TRACE: < OK
0000729933 [ncp.at] TRACE: > AT+UCGED=5
0000729940 [ncp.at] TRACE: < OK
0000729941 [ncp.at] TRACE: > AT+UCGED?
0000729949 [ncp.at] TRACE: < +CME ERROR: unknown
0000745049 [ncp.at] TRACE: > AT+CEREG?
0000745057 [ncp.at] TRACE: < +CEREG: 2,3
0000745058 [ncp.at] TRACE: < OK
0000745059 [ncp.at] TRACE: > AT+UCGED=5
0000745066 [ncp.at] TRACE: < OK
0000745067 [ncp.at] TRACE: > AT+UCGED?
0000745074 [ncp.at] TRACE: < +CME ERROR: unknown
0000759874 [ncp.client] TRACE: Sticky EPS denied state for 45 s, RF reset
0000759875 [ncp.at] TRACE: > AT+CFUN=0
0000759932 [ncp.at] TRACE: < OK
0000759932 [ncp.at] TRACE: > AT+CFUN=1,0
0000759940 [ncp.at] TRACE: < OK
0000760140 [ncp.at] TRACE: > AT+CEREG?
0000760149 [ncp.at] TRACE: < +CEREG: 2,3
0000760149 [ncp.at] TRACE: < OK
0000760150 [ncp.at] TRACE: > AT+UCGED=5
0000760157 [ncp.at] TRACE: < OK
0000760158 [ncp.at] TRACE: > AT+UCGED?
0000760168 [ncp.at] TRACE: < +CME ERROR: no network service
0000774468 [ncp.at] TRACE: > AT+CIMI
0000774477 [ncp.at] TRACE: < 310410122645095
0000774477 [ncp.at] TRACE: < OK
0000775177 [ncp.at] TRACE: > AT+CEREG?
0000775186 [ncp.at] TRACE: < +CEREG: 2,3
0000775186 [ncp.at] TRACE: < OK
0000775187 [ncp.at] TRACE: > AT+UCGED=5
0000775194 [ncp.at] TRACE: < OK
0000775195 [ncp.at] TRACE: > AT+UCGED?
0000775204 [ncp.at] TRACE: < +RSRP:
0000775204 [ncp.at] TRACE: < +RSRQ:
0000775204 [ncp.at] TRACE: < OK
0000790305 [ncp.at] TRACE: > AT+CEREG?
0000790314 [ncp.at] TRACE: < +CEREG: 2,3
0000790314 [ncp.at] TRACE: < OK
0000790315 [ncp.at] TRACE: > AT+UCGED=5
well, it was an easy one, I forgot to activate the SIM card!
