Dear all,
I’would like to publish on the cloud a basic text file (10 lines) who is stored inside a SD card (in .txt format) on the cloud using an Electron. I’m using the SdFat library.
Basically, I would like to change the Serial by Particle.publish() on the code just bellow:
myFile = SD.open(“test.txt”);
if (myFile) {
Serial.println(“test.txt:”);
while (myFile.available()) {
Serial.write(myFile.read());
myFile.close();
Thank you in advance for your help.
