There are examples in the example folder on GitHub, I am currently trying to get those examples to work on a Boron.
I am using a SparkFun microSD Transflash Breakout wired like this: (SD - BORON): DI - D12 (MO) DO - D11 (MI) SCK - D13 (SCK) CS - A2 GND - GND 3v3 - VCC
However I am having SD Card init issues, serial log as follows:
Serial monitor opened successfully:
0000009890 [hal] INFO: Using internal SIM card
0000011062 [app] INFO: failed to initialize sd card
Have you tried to use the example sketch on the GitHub repo?
EDIT: The Sd card seems to be working now. I just had to reformat the SD to FAT32
@rickkas7 Hi Rick, I know this is a stupid question but how do I actually use the test commands for this app?
particle call electron3 test "1,10000"
Should the above commands be passed via serial, or should they be placed somewhere in the app code?
Just realised its a CLI command, just call the function from the CLI. Very cool library Rick, I think it will really help our application.
