I'm developing a product that uses a SC16IS740 I2C bridge to communicate with a GPS module (BN-880). For power savings purposes, the GPS module is turned off initially, and power is sent to it when a reading is required. The serial bridge is powered all the time to avoid hot-connecting an I2C device.
In setup() I'm using Ricks excellent SC16IS7xxRK library to configure the serial bridge, and everything seems normal. After setup, when power is enabled to the GPS module, the device immediately hardfaults and gives either 1 or 15 LED blinks, but it's almost always 15 LED blinks (Secure Fault?)
If the GPS module itself is unplugged, or it is powered on all the time there is no crash.
I have a number of these boards, and some of them are not displaying this behavior.
Can anyone provide any insight into what would trigger a Secure Fault failure? Theres nothing mentioned on the Status LED and Device Modes - Photon | Troubleshooting | Particle page.
I'm pretty certain the issue is in my hardware, and I'm looking for any leads to help me find my issue.
