Safe Mode Trigger
Hello,
I was working on trying to get a P1 turn to safe mode from an external button in addition to the existing reset/power buttons to the controller, but couldn’t find any API(system.something(something)) call that which put P1 into safe mode?
I had originally thought it would have quite straight forward, but neither docs, nor forums turned up with the function that I need to call to trigger the Safe mode State.
Any help is much appreciated.
@amoghjain, you probably missed it in the docs:
https://docs.particle.io/reference/device-os/firmware/photon/#entersafemode-
Thanks!!! that was amazingly fast!
