Hey there, you've heard that we're looking for help developing Rust on Particle?
Let's use this thread to discuss development of Rust on Particle! Excite! ![]()
Letās get going!
Hereās a summary of our discussion so far from the PR conversation:
The user-facing API will be idiomatic rust, making effective use of traits. Traits will allow the capabilities of the system resources to be described and checked at compile time. For example, not all pins support PWM - traits will capture this information so attempts to use PWM on a pin that doesnāt support it would result in a compiler error.
weāll consider using parts of zinc.rs that allow bare metal interaction with the MCU, to provide an equivalent of the CMSIS API that C++ developers have access to on our platform.
for discussion: will the user API be object-oriented (OO), functional, procedural? Wiring++ and original Wiring are examples of OO and procedural API paradigms.
Iām not a Rust expert but Iāve played with it a bit, and am reading up on Rust idioms while I type some thoughts here.
fn main() {} standard basic Rust application format rather than replicating the whole setup() and loop() thing from Arduino. I see that Rust has a loop keyword so perhaps a template Rust app looks like this:fn main() {
// setup-y things
loop {
// loop-y things
extern crate particle;
use particle::photon as board;
fn main() {
board::pin_mode(D7, OUTPUT);
particle::publish("Photon is initialized!");
loop {
board::digital_write(D7, HIGH);
delay(1000);
delay(1000);
Another thought - since Rust is all about safety, itād be great to utilize that safety to ensure that boards and their peripherals are properly initialized. for instance, if you try to digital_write a pin that has not been initialized as an OUTPUT, it should fail on compile (with beautiful, easy-to-understand compile errors). similarly, if you try to initialize two peripherals that utilize the same pins, it should also fail on compile, perhaps unless you de-initialize the first peripheral before initializing the second?
Also, hereās somebody elseās attempt at mashing up Rust and Arduino:
Not my favorite, as it uses Arduinoās camelCase syntax, but there might be some interesting learnings in there regardless
Rust just announced 1.6, which is an important milestone for using Rust on embedded systems because libcore is now stable:
Is that possible? How would the system firmware support that? I'm sure this is among the things you're discussing internally. I would imagine that main is already an unmangled symbol in system firmware, but perhaps another symbol could be used? I'm really eager to help this move forward. ![]()
Itās possible to have main as the main entrypoint. With dynamic linking of the application code, ultimately itās boils down to a function address in a table - the name isnāt significant. This would replace what we normally use for setup(), and loop() could be a call to System.reset() , an infinite loop or some other appropriate action.
I left some comments on Github: https://github.com/zsup/firmware-rust/issues/2
Until we have a maintainer who will be organizing the effort? I would be more than happy to jump in today but not sure who is doing what and the priorities should be. Not to over manage something like this but I would participate in a Trello board to keep focus on priorities and who is working on what.
Iāll do my best to keep it organized, but the best place to dig in is on Github Issues, and we can use that to manage and prioritize efforts:
Does Rustās use of the GCC ARM toolchain mean no runtime-type-inference (RTTI) on ARM, just like C++ on ARM?
Rust only uses arm-none-eabi-gcc for linking, whereas the LLVM backend is used for code generation. Also, there is no 1 to 1 equivalent to C++ RTTI in Rust. But, depending on what you want to do, generics, traits and/or enums may cover your use. There is also the Any trait and the TypeId struct for dynamic typing and downcasting.
Disclaimer: I have limited experience with dynamic typing in Rust, but Iām sure the folks in Mozillaās IRC channels like #rust can answer any questions you have about dynamic typing idioms in Rust.
If rust needs RTTI for dynamic typing, we can enable that for the application firmware. Itās been disabled by default simply because of the increased size of the binaries produced. If thereās a way to only add this to the build conditionally upon the use of dynamic typing operators that would be ideal.
Is there anything that can be done on this project without actually having a board on hand?
Yes, lots!
We can discuss the design of the api, implementation choices, build systems. Thereās much that can be done without having the hardware.
Perfect!
Although, impatience kicked in, and I ordered a couple of kits yesterday, which will hopefully be here in a few days.
Iām still relatively new to rust (only started looking at it just before Christmas, and didnāt have much time in there), so Iām still a bit wobbly on some of the higher level constructs. That being said, Iād like it if we could keep things as close to idiomatic-rust as possible; Iāve a feeling that doing so will keep us from having to fight with the language as we go, and what Iāve learned so far is that rust fights you back when you fight it⦠hard. Also, the more idiomatic it is, the easier itāll be for those with rust experience to pick up and use the api.
I donāt believe itāll need RTTI, as thereās no dynamic typing in rust⦠at all. Even a single generic function (generics are rustās way of handling polymorphism) which is called by multiple different types, is turned into a separate āmonomorphicā function for each of those types at compile time. My understanding is that only those types that actually call that generic function will have a monomorphic function created for them at compile time ⦠so the binary wonāt bloat more than it absolutely has to.
@tjp I did take a peak, yeah. Being relatively new to rust, and completely new to Particle (as well as not having anything to test on), I figured Iād come here to ask the newbie questions, rather than cluttering up an issue thread.
Also, I wasnāt entirely sure that that was the consensus; There were a number of people in favour, but no āPerfect! Letās do it this way!ā, so I figured Iād add another voice to the consensus, just in case.
Either Iām looking in the wrong spot (incredibly likely), or itās all still very very nascent. So Iām left not really knowing where best to try and help out; Completely as a result of my own inexperience, without question.
Just saw /zsup/firmware-rust/issues/2 on GitHub (this portal wonāt let me link it, as more than 4 links show up in the preview pane)
⦠Clearly I need more coffee >_<
Sorry for tanking the S:N ratio
