Hi there
I’m trying to implement a function node.
The JS code is to use particle.callFunction() which require Photon Id and Access token.
For some reason I’m ignoring the Id is is being labeled as BAD number and the ACCESS TOKEN
cannot be inserted with all its characters.
Thank you for some help.
