When publishing events, say one named event every 5 minutes, is it possible to periodically query the event for all entries published on the event for a time period?
At the moment, no. This is something that’s planned for the future. It may, or may not be, part of the paid tier of the Dashboard. If you can set up your own server, you could log these entries to a database from which you could query them. I believe Heroku has a free tier which you can use for this.
Hi, Thanks for the response.
Woulds Webhooks be the way to go for this posting to my own server or ??
Webhooks, HTTP(S) directly, subscribe to SSEs from the server, or request them from the server using variables. If you’ve got a local server, TCP/UDP should work as well.
