Replace ethernet featherwing with WIZ850io
Hi all,
just wondering if it would be possible to use the WIZ850io in place of the Particle ethernet shield.
https://www.wiznet.io/product-item/wiz850io/
I can’t guarantee it will work, but it ought to since it’s just a W5500 in a much easier to solder form-factor with the connector already mounted.
Just make sure you connect the SPI and CS, INT, and RESET GPIO the same as the Ethernet FeatherWing, because the pins used for Ethernet are not user-configurable.
Thanks for that @rickkas7
Yes, I realise those pins can’t be changed.
Will give it a shot and let everyone know how it goes.
