Continuing the discussion from Cloud API incorrectly parsing DOUBLE values:
In case you weren't following this discussion, the "TEMPORARY_allTypes' JSON response is going away. So if you've written any code to query Cloud API results, you'll need to change that. Just thought this should be a "top level" post.
Dave O
